Sony Laptop Hi, I'm trying to replace the dvd drive in a Sony VGN-A690. How do I get in to change it? Do I remove the keyboard? The screen? If so how? Any help or advice would be greatfully received! Thanks Chris
  • 88 Answers
No its play and plug there are button under your dvd you can press both same time take cd
secound you can you put in tha hole
Posted on Aug 15, 2008
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
I need to know how to install a laptop hinge on a sony vaio a690? Is it required that I remove the lcd when I attempt to install the hinge?
As the hinge is what binds the display assembly to the laptop itself, you will need to remove the display assembly in order to replace the hinge. However, if you are only replacing the hinge cover, then you don't have to remove the display assembly.
Jan 09, 2011 | Sony VAIO VGN-A690 Notebook
My lcd is really bright then all these black blocks coming from the right going to the left no pictures, laptop works with a external ok. What am I looking for?
Please restart the computer and press the F2 key to access the BIOS setup. If the issue persist in the BIOS also then the issue is with the LCD screen, in that case service will be required to replace the LCD screen. You may either contact Sony Service Center at:
https://eservice.sony.com/webrma/web/index.do
Or you may also contact your favorite hardware vendor.
Based on the information, it seems that those are dead pixels and a LCD replacement will required.
The following are the Display part numbers:
A1062138A- Sharp Display Model# LQ170M1LA04
A8119991A - LCD Harness
468257801 - LCD Hinge (L)
468257701 - LCD Hinge (R)
468238001 - LCD Hinge Cover
147862922 - LCD Inverter
Thanks!!!!
Dec 28, 2010 | Sony VAIO VGN-A690 Notebook
How do you access the memory slot under the keyboard for a Vaio vgn-a690
Hi rmorrow002,
You can refer to the Computer model User Guide page number 175 to 183 for the detailed instructions (with images) to access the Memory Slots and Memory Modules in the Computer.
You can view and download the User Guide from the below link.
http://www.docs.sony.com/release/VGNA600series.pdf
Please follow the exact instructions in the User Guide. Removing the internal parts in the Computer may result series Hardware damages.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
Sep 30, 2010 | Sony VAIO VGN-A690 Notebook
Need service manual or instructions on replacing hard drive on a Sony Viao VGN-ns135e or Sony VGN-NS100 Series Laptop
The hard drive is inside of the laptop and not accessible from the outside. The way to get to the hard drive is to take out all the screws from the bottom of the laptop, take the keyboard out and there may be some screws there that need to be removed. The dvd drive needs to come out and where the dvd drive normally is, check for screws there.
At this point you can remove the top cover assembly and you will see the hard drive. Remove the screws that are holding the hard drive in place and then it will come out.
Nov 30, 2009 | Sony VAIO VGN-NS135E/S Notebook PC
Sound not working - Shows in device manager as ok. Properties are unavailable. I tried to reinstall driver. It was working at one time. I had to replace hard drive. Is there a connection under the keyboard...
Please follow the steps given on the article page through the link to troubleshoot the audio.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C171085
Jun 23, 2009 | Sony VAIO VGN-A690 Notebook
Disassembly manual for sony vgn a690
generally only held in with small screw on the bottom of case right at the end of where the drive is. then it just slides out
Feb 24, 2008 | Sony VAIO VGN-A690 Notebook
Sony A690 Memory Location
Some Vaio laptops (and some HP's) have a memory slot under the keyboard.
Jan 26, 2008 | Sony VAIO VGN-A690 Notebook
Vaio VGN-A260 dvd drive replacement
On my Sony 770 there were 5 screws under the drive and it slid right out.
Nov 18, 2007 | Sony VAIO A260 Notebook
Computers & Internet Logo
David Payne
David Payne
