Question about Mitsubishi WS-55809 55" Rear Projection Television
Ws 55809 i can solder;the directions would be great
  • 927 Answers
Good Day, richless;
I'm glad that you can solder. When soldering be careful as you know, as a profess solder, clean points with de flux or better acetone. May you have a great night, big IRISH.
Posted on Sep 02, 2008
Color changing while viewing
Sounds like your TV needs new convergence chips.
Go to this web site.
http://www.tvrepairkits.com/xcart/home.php?cat=2653
If you can handle a soldering iron and solder fairly well, then you can do the repair.
Hope this helps.
Apr 03, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Just bought this used Mitsubishi WS-55809 and when I turn it on the pic. is all messed up. The write is deformed looking and all the words are repeated 3 times. I hit the back of the TV and the pic. and...
Sounds like you have some solder problems on your deflection board. If you're up for it, you could fix that yourself with some solder and a soldering iron. Just take the back off, and look for the board with 2 of these on it (numbers may be different).
Remove the board carefully noting where you unpug things (take photos if needed). Then reflow the solder joints on these parts. I hope this was of assistance, best wishes.
Mar 29, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Red convergence on my ws-55809 is off
The lense adjustment won't help. There are two convergience chips inside, each has 16 pins. If you take the big tray, with all the boards, out and turn it over, you will see that one of the chips has a pin that goes to a contact labeled, "RH." You can't miss the chips, they are stuck to a huge, finned heat sink, about 4'' x 7". Check the continuity from that pin to it's contact with an ohm meter. You may get lucky and get by with simply a re-solder or jump on that pin. Those convergience chips are like computer processors, are subject to extreme heat, depend very heavily on their heat sinks and cooling fins and could easily get hot enough to break a solder connection. Like computer processors, they should have been designed with fans as well as heat sinks. Don't kill yourself. Even unplugged, a tv has enough stored energy to be fatal.
Mar 08, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsubishi HD 1080 Model WS-55809 - the colors are distored. The picture is like double vision. For example the menu words all have yellow & red shadows.
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My 5 yr old mitsubidhi ws 55809 convergence.
The convergence output ic's must be replaced and some solder rework on associated connectors.
Apr 30, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 installing STK392-570
un solder ics replace both of them resolder make sure you do not solder any of the circuits together or it will short something out,also ck low ohm resistors in same circuit.I will try to help you the best that i can. Main key you must know how to Solder.
Dec 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 Color
Does the neck of the tube glow? If not you may have a bad solder connection on the Red CRT PC board or a bad transistor on the red PC board
May 20, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Picture problem
start checking caps w esr meter probally leakey cap or solder conn.
Apr 21, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Screen turning pink
If the pink overlay goes away gradually, you could have weak picture tubes (CRT's) If the color jumps in after warming up, it could be a bad solder connection. If you haven't had a good picture to watch for a long time, I would be tempted to put the money towards a new HDTV set as those older Mitsubishi Rear Projection TV's had a Lot of bad solder connections in the past, and by fixing one problem another could crop up in the near future.
Apr 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
