Question about Mitsubishi WS-55807 TV
Colors on screen
Colors are distorted .Someone said i need a color gun. Is there such a thing? Pricey?
  • 927 Answers
Good Day, richless;
It sounds like your TV's convergence circuit has failed. This is not an easy repair for a novice, so I would recommend that you call an Authorized Service Center and have them give you an estimate.
Good Luck, big IRISH.
Posted on Aug 16, 2008
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Color distortion-Sony Bravia Model KLV32EX500
check for a loose connection in the t-con board tried with re seat the cable wire in the t-con board.
Oct 04, 2012 | Televison & Video
The colors seem to be overlapping the red is further off than the other two
Hi, you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.The other thing that it could be is the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Mar 24, 2010 | Samsung HLN5065W 50" Rear Projection...
The colors on my TV are shadowing each other in different colors. Such as blue and red.
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Televison & Video
Colors don't line up, and screen is distorted on a sony KP43HT20
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
  • Dull looking video
  • White looking video
  • Red/Orange looking video
Dec 08, 2009 | Sony KP-43HT20 43" Rear Projection...
RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Nov 01, 2009 | RCA 27R410T 27" TV
Distorted Colors in Ipod Classic 120G Screen
you might need to get a new screen for a classic ebay would be a good choice because apple will charge the earth for a new one
unless your still under warranty
May 28, 2009 | Apple iPod classic MP3 Player
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
