Question about Sharp Actius MC24 Notebook
COMPUTER PLAYS DISK BUT NO SOUND
Sharp laptop computer-power GW9WDIQWI
Speakers wont come on
Lets start with the basics.
1. Make sure the power cord to the computer speakers are plugged in. Check at the wall and make sure the power cord is connect to the back of the speaker. If there is a power button make sure it is pressed in the on position. Make sure the volume level is turned up.
2. Check the computer and make sure the sound is not on mute. Turn the volume level up from the computer settings.
3. Try playing some music. If you hear sound you are good to go.
4. If you are not able to hear anything than continue. I would suggest plugging your speakers into you cell phone. Try playing some music from your cell phone.
5. If music plays through the speakers from your cell phone, something is wrong with the computer. If no sound plays with your cell phone then something is wrong with the speakers.
6. If worse comes to worse bring your computer into a computer store. Tell the salesman you want to buy a new set of speakers. You just want to make sure your computer works with the speakers before you buy them.
7. If all else fails, ask a local tech you trust.
May 25, 2015 | Audio Players & Recorders
Apple MacBookPro 2010 is in a white screen
If the start up sound plays and the hard drive sounds normal try connecting the computer to an external monitor. If the external monitor shows the desktop just fine then the cable connecting the laptop to its screen is probably going bad.
If the computer will not boot at all try zapping the PRAM by
  1. Pressing the power button and then command-option-p-r before the gray screen comes up.
  2. Hold those keys down until you hear the startup chime.
  3. Let go of the keys and let the Mac reboot.
If that doesn't work try booting from an install disk and run a repair utility.
Jan 28, 2014 | Apple 13" MacBook Notebook Computer ...
I burned a movie on a +R DVD. It plays on my computer but not my Mintek DVD payer. Why is that?
computer disks are different then DVDs. you probably burned on DVR format. you can get a converter and make sure the file on the disk is AVI or, DVD
Sep 20, 2013 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
I have a clicking sound on myvista laptop when i try to power on ,it does not go on.
Clicking Hard drive
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
You need to replace the hard disk and install Windows and your programs to get a working computer again.
May 07, 2013 | Dell Inspiron Computers & Internet
It wont turn on
Sounds like your hard disk has failed.
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 30, 2012 | Computers & Internet
I have a sharp AR 5625 photocopy machine that brings a message 'maintenance is required ' how do i solve it?
Are You the Administrator for the System?then go to the folder On the computer it's connected to and run Diagnostics from there, And Or from the control Panel/ Devices/Hardware,Also Right click Computer go to Properties device manager click on Printers if you have a yellow Icon on anypart of that list then y have a software Problem, go to MANUFACTURE Web site and Download the latest sofware for you're machine restart after install and you should Be fine , ALSO DON'T forget to run you're computer tools Like disk clean up and disk defragmenter, to keep you're System in top working order
May 24, 2012 | Alienware PC Systems ALIENWARE 5620D...
When plugged in it to the power it plays a song
If you have an older model computer it may not be able to handle that size drive.
Try again after demagnetizing your hands--touching the computer chassis or using a anti-static wriststrap
Dec 18, 2009 | Maxtor DiamondMax 10 200 GB Hard Drive
When the computer is turned on via the power button, the computer does not come on. When I check the LED indicators, the on/off indicator goes green, the battery power indicator is first orange, then...
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 30, 2009 | Computers & Internet
My hp computer does not produce sound
you can find your sound card drivers at www.hp.com and also your HP Computer have its own utility disk or driver installer, use it to install...
Jun 20, 2009 | Computers & Internet
Cannot get sound
Check and make sure you don't have your computer muted. That is the most common cause
Mar 28, 2008 | Computers & Internet
Sharp Actius MC24 Notebook Logo
61 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
