Question about Panasonic Workio DP-2500E Copier
E07-11 check scanner unit
E07 code needs to be cleared
  • 100 Answers
You may check the sensors(home position sensors) of the scanner unit because e711 means abnormal platen scanning
Posted on Aug 22, 2008
Dear Sir, Our Scanner was showing to change magenda toner and we change with new one, but after end of the process it is showing the error code of E000020-81, even after shutdown 3 times. What else I can...
The error code your gettting E000020 is a drum code (imaging unit). You however do not have the complete digits after the E000020-????. Those digits define which drum needs to be replaced. You don't need to go into service mode to clear the error. You only need to buy the correct drum and put it in with the power off. Once it is replaced and the machine is turned on it will register and clear its internal error code. To help, here is what the ending codes mean. The xx's have further meaning but in most cases all roads lead to the same result (replace drum imaging unit).
-01xx yellow (Y)
-02xx magenta (M)
-03xx cyan (C)
-04xx black (K)
Jun 25, 2011 | Canon imageRUNNER C3200 Copier
I need to know how to reset my computer on my 2001 hyundai santa fe
First you must purchase a scanner with OBDII capabilities that can read and clear codes. Then you connect the scanner to the OBD diagnostic connector under the dash and perform the code clearing per the instructions with the scanner. A generic OBD scanner with these capabilities can be purchased at the local parts stores for around $70.
Apr 14, 2011 | Hyundai Santa Fe Cars & Trucks
Computer showed that we have to change crankshaft position sensor in a 2005 Saturn Ion , we did it but the check engine light is still on. How to do a reset to make the check engine light go off?
You can take the negative terminal off the battery and let it sit for at least 15 min, then reconnect and turn the key on and wait for the diagnostics to turn the lights off, then turn the key on and let the computer re-learn its idle pattern and such, this should clear it if you have repaired the defect. If it doesn't clear then the repair wasn't correct or not installed correctly and needs furthur attention.
Feb 27, 2011 | Saturn Ion Cars & Trucks
How do you reset the "check engine" light on a 2004 Kia Sedona
you need a scanner obd 1 you could undo the battery or pull a fuse but obd2 needs a scanner too clear the codes you could go too autozone they will read the codes for you and clear them and try too sell you a part that probly wont fix it but if you clear it and its not fixed it will come back
May 14, 2010 | 2006 Kia Sedona
I have a 02 TB and throws a code of P1271 I changed the apps and it still is giving the code I checked chevy forums last night and some said check the fan cluch I cleared the codes unpluged the fan and no...
you have to clear code with a scanner sorry hope this helps i to have had better days if you cleared codes with scanner then try unhooking batterie for 2 minutes negative side then clear with scanner again and recheack scanner for code you must clear with a scanner there is no other way
Dec 04, 2009 | 2002 Chevrolet TrailBlazer
Sharp AR 507 has a code L3-00 Scanner will not retun home in time
I turned the copier off completely, then turned it back on -- it seemed to resolve the L3-00 issue.
Apr 30, 2009 | Sharp AR-507 Copier
Call for sevice
Correction, you need to press "clear" and "8" simultaneuosly and hold to display error code...
Apr 13, 2009 | Toshiba Estudio 200L Copier
Toshiba e studio 150
on the toshiba Estudio 150 there is a lock for the scanner unit underneath the left side of the scanning unit where you would put your hand to get a copy. what happens most of the time is someone unintensionally turns that know which in turn gives the error code because the scanner cannot move. check to make sure that the lock is in the unlocked position. this plastic lock can be removed with a screw driver. other times we have found that the scanner rail underneath the glass needed to be lubercated with a light oil. to do this the four top screws on the top corners of the machine would need to be removed and the glass will lift off. once the glass is off you will see a silver bar that runs across the scanner unit that the scanner rides on. take some light oil like typerater oil put on finger and coat the siver rail with it by running you finger of oil on it. put back together and try. if that doesnt solve it the only other thing i have seen is broken scanner lamps and in that case it needs to be repaired by a service tech.
Jan 03, 2008 | Toshiba e-Studio150 Copier
Panasonic Workio DP-2500E Copier Logo
167 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
