Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX30 Hey I just bought a Hobart Lx30 and we don't have a power source that can handle the 50 amp requirement. We got it at an extremely good price so we are trying to work around it. I was told that disconnecting the water heater would allow it to work in a standard 120 volt outlet. I did that and now I have another issue. The machine wont run unless the water is 160 degrees. How do i disconnect the sensor that restricts the temp so that I can run the machine at a lower temp?
    Problem Solver:
  • 6 Answers
Hopefully you took the suggestion to run the correct 50 amp 208-240 service to the unit.
Converting the unit to an LX30C has a couple of pitfalls. The LX30C is connected directly to the incoming water supply, which should run 120-140 degrees. By reprogramming the unit as an LX30C, the booster would be disabled, which would mean the incoming water would flow through the de-energized booster and be cooling off while it sits in there between cycles and when the unit is shut down.
The incoming fill plumbing (5/8" heater hose) would have to reconnected from the fill solenoid valve directly to the vacuum breaker on the rear of the unit to bypass the booster heater.
On the 208-240 volt LX18/30/40's, the pump motor, booster heater, and sump heater run on 208-240. To convert it to 120 volts you would have to replace the sump heater and reconfigure the motor wiring in the motor junction box.
By the time this is all done, you've downgraded a great machine, confused the next service guy, and have to deal with nasty chlorine and all of it's headaches.
I
Posted on Sep 12, 2009
    Scholar:
  • 109 Answers
Reprogram the control board for LC30C spec, and buy an sanitizer pump kit for about $500.00, or spend the money and install the breaker and wire it as per NSF/CSA spec. Not sure if your insureance will appreciate modifications to an approved unit, if there is a fire related to your mods.
Posted on Aug 14, 2009
  • 38 Answers
I'm sorry, but I doubt you will find someone willing to assist you in this.
What you are proposing will violate the NSF Certificate for sanitation and could pose health problems for users of the ware cleaned by this machine.
I would suggest the machine be installed correctly
Posted on Aug 19, 2008
  • 640 Answers
I service these units all the time---im a tech for hobart.Do you want the wash temp to be lower?im assuming you disconnected the booster tank for 180 degrees so it wouldnt trip your breaker.If you disconnect the wash tank thermistor the wash tank heat will only get to the temp that your hot water heater is supplying.Let me know
Posted on Aug 24, 2008
SOURCE:
I have a Hobart Dishwasher model LX30, it seems to stall when in the fill cycle from the start, which blocks any further function except shutting down, on the screen there appears a wrench insignia.
Hobart LX30H ML 104354 Manual Page 28
According to the manual ... the wrench icon comes on with OTHER codes for the LX30. Did you get a flashing P1, P2 or P3?
Or for that matter, get any associated E codes to come up?
Depending on the P or E codes there are fixes discussed on prior Fixya answers for this machine ... search there for more help
Mar 05, 2018 | Hobart Dishwashers
What is the fuel ratio for a homelite LX30 chainsaw,ive been told 30/1 50/1 25/1 40/1. Which is correct thanks.
Find an oil you like and mix it according to the oil recommendations.
I use Opti-2 in all my 2cycle fuel mix and it's a 100:1.
What the oil manufacturer says to mix the oil/fuel is what you go by, not what the engine manufacturer says.
Opti 2 2 Cycle Oil 34oz EZ Measure Bottle 20112 eBay
Mar 05, 2018 | Homelite Garden
Manufacture date hobart LX30 H. Serial 23-1044-007. ML 111 4354
If it is before Kitchen-Aid got involved, it is from the era before the 1986 buy-out by Whirlpool, so it is 30 years old at minimum!
Jul 12, 2016 | Hobart Dishwashers
Have a hobart lx3011 and just quit working. where and how many fuses in it?
Not sure if you have an LXIC or an LX30.
Both have a pull out drawer at the top. Both have the main connection of power on the contactor in the front left corner. Both have control circuit fuses between the contactor and relay board.
Use caution with a digital meter to test.
Mar 15, 2014 | Hobart 24 in. LXIC-5 Built-in Dishwasher
E3 Error code on hobart lx30 dishwasher.
my dishwasher Hobart LX 30 will not shut off and displays 30
Jan 21, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX30 error code wrench & E5
What error code is displayed?e1,e2,e3,e4?I'm a hobart tech let me know.
Apr 10, 2009 | Dishwashers
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Detergent error
I'm a hobart tech---been away for awhile.What is the model lxih,lx30?Let me know if you still have a problem with it.
Jan 02, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart lx30 : rinse cycle
The rinse water in a LX30 is driven by water pressure. A solenoid valve, bottom front - gold body, opens up and allows the water to flow.
If you are referring to the rinse agent pump, there must be NO leaks in the tubing or the hose that runs through the pump. And if the unit has lost its prime, using your hand to "seal" it, and forcing water from the faucet into the line can prime it.
Good luck - Mike
May 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart fx25 dishwasher
I think you may have the wrong model number of the dishwasher.I work for hobart but i dont recall a dishwasher with the model number you givin me.Look on the data plate again some examples of hobart dishwashers are--sr24---am14---c44---c44a---lx18--lx30--lx40---lxi---uw50--sm6t2.Once you find the model goto this site and you will find a manual.any other questions let me know.http://www.hobartcorp.com/default.aspx
Nov 22, 2007 | Dishwashers
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
569 people viewed this question
Top Hobart Dishwashers Experts
GPEC
Level 1 Expert
Jason
Marvin
Marvin
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
