Question about Panasonic PT-53WX42 53" Rear Projection Television
Blinks The power light flashes three times but no picture or sound.
  • Anonymous Aug 21, 2008
    I have the same problem on the same set. Have unplugged and let sit for 4 + hours as suggested and still it doesn't work. This was all of a sudden at the first time it was turned on for the day. Any thing else I should look for? I was told that it was the power supply code. I like the ICs better. Thanks
  • Panasonic Master
  • 8,617 Answers
You need to replace both convergence ICs that is what the 3 blink error code is for your model. You need two STK392-110 Convergence ICs you can get replacement ICs at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Posted on Aug 13, 2008
LG 32LM3400 turns on and light flashes three time but no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 24, 2016 | LG 32LM3400 32" LED TV 1366x768, 100 Hz,...
42 inch toshiba red light blinks three times no picture or no sound
Toshiba e-studio 18 every morning frist time copy light and background
Oct 31, 2013 | Office Equipment & Supplies
Red standby light came on and no picture sound is ok .Next. time tv came on it played approx one hour everthing ok. then the picture gradually faded away . Red standby light came on again. Still no...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 08, 2011 | Sony Televison & Video
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a Sony Trinitron 32" TV. The picture don't
Hello
Blinking of standby light in Sony sets are fault indications. You just count the number of blinks occur at a time, by switching the set ON-OFF by its front panel power switch, not by the remote control handset. Just do it for at least three or four times, count the exact number of blinks occurs there, and inform it to me through Fixya. Through the number of blinks, I can locate the faulty section, of somtimes to the exact fault location. Count it keenly and inform me. OK.
Dec 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The stand by lite flashing I have sound but no picture
Hello
Blinking of standby light in Sont TVs denotes fault indication. You just count the number of blinks occurs each time you switch on the TV. Please switch it ON and OFF by its front panel power switch, and not with the remote control. Do it three or more times, and keenly look at the number of blinks; confirm it, and send it to me through Fixya. OK.
Dec 02, 2010 | Sony KV-32XBR250 TV
Red power light flashing..no picture
Count the blinks of the led. The number of blinks gives an idea of which board has failed let me know
May 01, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Panasonic PT-53WX42 53" Rear Projection Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
