Question about Zanussi Washing Machines
Need to remove object in drum - Zanussi Washing Machines
I have a Punch WF-C5856TC topload washing Machine. How can I remove odject that have been stuck inside?
Posted on Oct 23, 2009
Screw stuck behind drum making it not rotate
You will need to remove the drum and assembly, please check on this link for tips: Drum removal
Jul 07, 2012 | Washing Machines
An small object has become trapped inside the drum. How do we get access to the drum to remove it.
you must remove the front panel,pull out the heating element...and there you can(posyble)find that small object
May 23, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Dryer works, but makes noise.
There are a lot of moving part that can cause noises or vibration when get worn out.
  • Make sure dryer is level, and on a secure floor, and that nothing is leaning against the dryer.
  • Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a squeak.
  • Check for foreign objects below the lint filter:-Remove lint filter, and look down opening. If you need to stick your hand down the opening to remove an object, be careful because the edges could be sharp. It would be advisable for you to wear a pair of work gloves.
  • Foreign objects in the drum front seal and worn or loose drum slides can cause a metal scraping noise as the drum rotates.
  • Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
  • A frayed or damaged belt will make a thumping sound.
It is normal to hear the sound of the drum as it turns. If your dryer is making unusual noises and the above suggestions do not resolve the situation, discontinue use of the dryer until it has been checked by a qualified servicer. Continued use may cause wear of other parts making the repair more costly.
Thanks..!!
Sep 19, 2010 | Kenmore Elite HE4 Electric Dryer
Metal (wire?) stuck in rotating drum cavity.
Firstly, you can carefully run your hand around the inside of the drum. If you're really lucky the object may poke thru one of the holes enough for you to grab with a pair of pliers. Try turning the drum back and forth to catch the object in the holes. If this doesn't work you can take the sump hose off on the bottom of the outer tub. If all else fails you may have to remove the heater element and more than likely that's where the object is stuck. (Please ensure if you do not but a new element in use some petroleum jelly or washing liquid to get the old element back in, or you may solve one problem but create a leak). Also, when refitting element be sure that it is sat under it's internal bracket or the drum will scrape on it when it turns.
Hope this helps
ps I'm betting evens that it's a bra underwire!
Jul 07, 2010 | Bosch Washing Machines
Horrible scraping noice when drum rotates
YOU WILL NEED TO REMOVE DOOR SEALING RUBBER WHICH SEALS THE TWO HALFS OF THE DRUM THIS WILL ALOW YOU TO REMOVE SAID OBJECT
Dec 28, 2009 | Washing Machines
We are trying to get drum out to remove trrapped object please help. have been told it pops out easily HOW??????
remove front seal from front panel then undo front panel to expose the drum at this stage you may be able to remove object if you can see it if not undo pulley and inner bol should pull out let me know how you went
Nov 05, 2009 | Zanussi ZJ1217 Front Load Washer
An object is caught behind the drum of our Kenmore
remove the back and check if large pulley is wobbely on shaft. common problem. replace pulley.
Jun 12, 2009 | Kenmore HE2 Plus Front Load Washer
Hi.. hope you can help me.. I have a year old Zanussi ZWF1221W - my dear daughter put in a wash without emptying her pockets and something (a hairgrip or bra support) is now stuck between the drum and the...
It sounds like it's actually stuck between the bottom of the agitator and the basket (assuming you've got an agitator). The top of the agitator is usually for bleach or maybe it's fabric softener. Pop off the top (like the lid off of a can) and that should expose a nut or bolt in the center of the agitator. Remove this bolt (make note of how tight it was just after you've broken it free) and lift to remove the agitator. Remove any foreign objects and feel free to clean up anything else down there. Replace the agitator and tighten the bolt approx as tight as it was when you removed it (be careful not to overtighten). Snap on the top of the agitator and you should be good to go.
Mar 18, 2008 | Washing Machines
Filter
You will need to tip it back and remove the sump hose from underneath. make sure you unplug first.
Feb 24, 2008 | Hotpoint WMA66 Front Load Washer
Water inside the drum
there may be a foreign object that is partially blocking the drain from the outer drum. open the back and remove the drain hose connection from the drum. Using a long screwdriver as a test prod, carefully try to feel this foreign object. Also try to look up into the drain outlet using a flashlight and mirror.
Aug 18, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
152 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
