Windows XP Professional
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=55820EDB-5039-4955-BCB7-4FED408EA73F
or
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
Step 2: Run the Setup disk program to create the Setup disks
When you download the Setup disks, the download contains only one large program file. When you run the downloaded file, it extracts the files. You receive the following message:
This program creates the Setup boot disks for Windows XP. To create these disks, you need to provide 6 blank, formatted, high-density disks.
Please specify the floppy drive to copy the images to:
Type the drive letter for the floppy disk drive (this is typically drive A). After you type the floppy disk drive letter, you receive the following message:
Insert one of these disks into drive drive letter:. This disk will become the Windows XP Setup Boot Disk.
Press any key when you are ready.
When you press a key, the downloaded file starts to extract and copy the files. Continue to insert the blank disks as you are prompted to do this until all six disks are created. If the process is interrupted, you must run the downloaded program file again to create all six disks.
Make sure that you label each disk appropriately with the number that is specified by the program. You must use the disks in the correct order during the Setup process.
Step 3: Start your computer by using the first Setup disk to begin a new Windows XP installation
After you create all six disks, insert the first disk in the floppy disk drive, and then restart the computer. The computer must be configured to start from the floppy disk drive. You may have to modify the BIOS settings on your computer to do this.
The Setup process starts. Insert the other floppy disks when you are prompted. You must use the Windows XP CD-ROM to finish the Setup process.
hope it helps
hope it helps
Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
