GE Caddx Networx Fixed English LCD Keypad   NX1448E Logo
Posted on May 14, 2011
NX-1448E keypad sometimes beeps when nothing was opened. Is there an easy fix? Also, how to remove keypad door to write zone descriptions. Thank you, Doug Burton
3 Related Answers
cesar_quant
Cesar Quant
  • 74 Answers
  • Posted on Mar 09, 2009
SOURCE: zone alarm code
check all the wire to that zone, magnets or movement sensor`s led is lit with every movement, it might be a damage wire or a mice bite hehehe, check the panel and make a bridge between the zone number and the common if the led zone turns off, u definitely have the check the wiring and magnets... becareful !! some magnets can give false contact... use a tester to measure continuity, other wise contact a troubleshooting for that brand....
Anonymous
  • 74 Answers
  • Posted on Aug 23, 2010
SOURCE: hi i have a ge Caddx NX-148E-RF - beeps only on the hour anoying
Press * 2 and it should tell you what the problem is.
AlarmProfessor.net
Anonymous
  • 591 Answers
  • Posted on Aug 22, 2011
SOURCE: I have a Radionics 6112
It's a defective key pad or a defective wire from the panel to that key pad, with the help of a certified technician try switching the keypads, if the problem is the same than it is a defective wireing, if the problem change from keypad #1 to keypad #2 it's a defective keypad... as symple as that...
1helpful
Having problem with wireless smoke detector on my NX-8. Is deleting current program and reprogramming the way to go?
Before deleting the current program and reprogramming your NX-8 wireless smoke detector, you may want to try the following troubleshooting steps:
  1. Check the batteries: Ensure that the batteries in your wireless smoke detector are not dead or low. Replace the batteries if necessary.
  2. Check the signal strength: Make sure that the wireless smoke detector is within range of the NX-8 control panel. You can try moving the detector closer to the panel to see if it helps.
  3. Check for interference: Interference from other wireless devices, metal objects, or thick walls can affect the signal strength. Try removing any potential sources of interference or relocating the detector.
If these steps do not resolve the issue, then deleting the current program and reprogramming the wireless smoke detector may be the next step. Be sure to follow the instructions in the NX-8 programming guide to properly delete and reprogram the detector. If you are not comfortable with programming the system yourself, you may want to contact a professional alarm company or technician for assistance.
Dec 01, 2022 • Home
How do I fix a buzzing sound in my fridge?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Honeywell ADEMCO 6150RF keypad sporadic constant beeping
It is trying to indicate a problem with zone 1. check it out.
We have an NX-148E keypad. Our building has 4 doors alarmed to the panel and the Chime sounds when any of the doors is opened. Is it possible to set the Chime only to sound when 1 of the doors is op
I am sure there is separate programming for each zone. You will need the manual for the system. Probably can get it on line. This chime feature usually comes from the factory with no zones programmed for reporting. Hope this helps
2helpful
My key pad is displaying not ready chime only
Not Ready means one or more of your zones is faulted. Pressing the * key on the keypad will display the zone or zones that are faulted. A faulted zone can be a door or window open, a motion detector "seeing" movement, and so on. It will also display a description of the zone. Chime means the chime feature on the keypad has been enabled. Any perimeter or entry/exit zone that faults will cause the keypad to ding three times. This can be turned off by entering your 4 digit code and pressing the 9 key. Doing so again will turn it back on. The link below is for the user manual for an Ademco Vista 20P panel.
Hope this helps.
http://panelguides.com/panel-guides?task=view.download&cid=1181
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
2answers
Zone alarm code
I do not know that make, but, it could be the contact and magnet not in line or water ingress or maybe just a faulty contact. Check your manual for a reset procedure.
I hope this helps ?
Ademco Alarm System - Zone works opposite? Triggers on (door closed)/ Stay Off (door opened)?
i dont think it polarity not unless alarms in the usa are different from nz aus uk sounds like you have a faulty something. try open and closing the front door and look at the keypad to see if the zone activates as it should. there can only realy be 3 things. device, cable or panel fault. you can easly test the system by swaping the zones in the panel ie zone 1 to 2 and 2 to 1 providing that they have similar zone charectorists ie "entry exit" if the fault moves to the other zone you know its a device fault.(inspecting the cable for damage is probably the easy thing to do) if its a reed switch you could look at the position of the magnet it may be making borderline contact and a slight movement of the door could be tripping the zone. if the fault doesnt move its a panel fault. before you jump in though make sure that if you dont comprimise your protection or insurance by trying DIY security. good luck (if you have no joy post more details)
3answers
Keypad doesn't work
check control panel and clean the control circuit, any moisture is there clean the circuit. any dry solder is there check overall circuit and confor it ...door switches and sensors
Top GE Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Home Security Expert? Answer questions, earn points and help others
