Yah your video card is fried had the same problem unless its under warranty i suggest new from what i understand the table you need for putting the sauder to connect it is like 1k so def just new
Umm if you have sound then your yellow av cord must be faualty (The yellow av cord is the one that produces the pictures onto the screen) But if you have no sound and the power brick and xbox is humming away nicely then i recomend taking it to a repairer to try and get it fixed.=]
When it is starting up push down y and pull the right trigger the console will reastart on default settings and u it will show the picture if this dosent work try when you hear the menu screen come up. It worked for me but now i have lines going acroos hopefully you wont have tht problem
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
I had the same problem my xbox 360 just broke all of a sudden and then I used this guide to fix my xbox 360 plus it only takes like an hour. Good luck dude.
