Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
I have a 18 Volt Makita drill , model # BDF 452 which I've used only 3 or 4 times . The last time I used it , I could not remove the drill bit . The chuck will not turn/loosen to release the bit . Any suggestions before I have to send it in for warranty repair . Thanks , Larry
  • 659 Answers
Oh I hate when that happens. ushally its due to not being lined up right inside the unit. happens with my cheaper drills more so then not.
I ushally just secure the bit into my vice, and then tap the the key with a hammer to loosen the threads..
sounds like she might need a bit of oil I ushally use air compressor oil just a couple drops work for me.
Posted on Aug 13, 2008
Keyless chuck drill just spins
Some times the selector on top get gummed up with dust, it just needs cleaning. You were right to put it into 1st gear to remove the chuck with a big allen key, you get more resistance in the gears.
May 30, 2012 | Makita Drills
I have a 18 volt makita cordless impact driver i can not get the driver bit out it seems to be stuck in the chuck very tight
Try holding the bit with pliers and running in reverse, maybe with a shot of oil. That might free it up. You can also try tapping it (firmly) on the side of the bit
Aug 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Broke bit inside chuck and piece is lodged in there now. Pulling out on chuck release does not allow broken part of bit to come out. Do I need to take drill apart or remove chuck to get broken bit out of...
TAKE THE OUTER CHUCK PEICES OFF THE IMPACT!! THERE WILL BE A C-CLIP, WASHER, SPRING AND ONE OR TWO BALL BEARINGS AND THE OUTER HOUSING, IN THAT ORDER! WITH ALL OF THAT OFF, MOUNT THE ANVIL IN A BENCH VISE WITH BRASS JAWS OR BETWEEN TWO PEICES OF WOOD, UPSIDE DOWN!!!!!!!!!!!!!!! THE TRICK IS TO HAVE THE BIT FALL OUT OF THE CHUCK ONCE IT IS LOOSE!!!! NOW WITH IT MOUNTED IN THE VICE AND PRETTY TIGHT, TURN THE TOOL ON UNTILL IT FALLS OUT, IT WORKS GREAT IF HAVE DONE IT ABOUT 75 TIMES!! MOST PEOPLE THINK I'M A WIZARD!! BUT IT'S REALLY EASY. WITH IT MOUNTED SOLID IN THE VISE THE ANVIL HITS SO FAST AND HARD IT VIBRATES THE ANVIL, IF YOU DO NOT REMOVE THE BALL BEARINGS HOLDING THE BIT, YOU WILL BE DOING THIS ALL DAY. SOMETIMES, IN THE CHEAPER BITS IT WILL ROTATE AND GALL UP SO BAD THAT IT WILL NEVER COME OUT, IN THAT CASE YOUR BUYING A NEW ANVIL ASSY. JIMS TOOL SERVICE
Jan 11, 2011 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Makita 14 volt cordless drill, model 4337, just decided to slowl down and go dead.\r\ndrill is beyond warranty period and has been used only 5 or 6 times. does any one have any ideas???
The batterys don't last for ever dosn't really matter how many times you use it but never leave it in the garage or cold places that will distory the battery life and mermorey. Its a good gun so it may be worth getting new batterys just try to run them down all the way before recharging and never leave batterys in the cold and it will work and least 3 to 4 years before you need new batterys
Dec 14, 2010 | Makita Drills
How do I remove the Chuck from my Mikida 9.6 volt keyless drill
Dont know about a Makita, but my Craftsman drill , if you open the chuck all the way and look inside the hole where the bit goes, there;s a screw there that you can use to remove the chuck. amybe yours is the same way.
Nov 23, 2010 | Makita Keyless Drill Chuck Set, HP1501...
Led light does not go off after use on a BDF 452 cordless drill?
not sure what the solution is but if you decide to open up the drill be very careful. all the guts only go in one way or the case won't close.
Sep 01, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Makita ML902 Flashlight how to open case housing to repair
Makita ML902 - great flashlight. but I wanted to upgrade the lamp to LED, and found that the POLARITY was wrong . so i HAD to open the dern thang. the 'special tool' and 'keep in-house' conspiracy had me 'fuming' ... turns out if one were to mark the EXACT spot that the pivot occurs with a felt pen, by drilling a small (sized) hole on each side, (stop as soon as the bit is thru! the shiney material that you stop at are lamp straps) then pressing 2 stiff objects from both sides, the head pops off ! one more screw is uncovered, making it an even 4 screws holding it all together. When i opened the case up, one wire wasn't even soldered to the switch ! aargh. so - swapped polarity, re-soldered the connections, add a bit of fresh solder, re-assemble, voila! I love the 9 volt cases, upgrading everything to 12v and 16v lithium 18650 cells. these old Makita ensembles are great! saw, drill, angle drill, light...
Mar 29, 2010 | Makita Drills
How to fix or replace a electric brake problem on a makita bhp451
you would need to replace the switch, but before doing that check the brush length for excessive wear. you can go to Makitatools.com for a breakdown for this model.
Nov 29, 2009 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Hammer drills Features
There are a few features you may want to pay attention to include: A Depth Rod mounted to the drill lets you know when the bit reaches the desired depth; Variable Speed Selection allows you to adjust the drill for specific jobs. Use high speed for small holes and low speed for large holes; Reverse can retrieve a hopelessly stuck bit; Removable Side Handles give the operator better control in normal use, and can be removed in confined spaces.
Aug 27, 2008 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
386 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
