Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper Jam ON my Canon Pixma MP150 the paper always gets jammed, or several pages go through. What can I do to have it run smoothly
  • Montie69 Aug 18, 2008
    It seems to have worked.
    Thanks.
  • Ariesnfs Oct 15, 2008
    I HAVE THE SAME PROBLEM BUT MINE, THE PAPER GET STUCK AND THE PRINTER REFUSE TO PRINT I TRIED TO FIX IT BY THE WAY U SAID, BUT STILL...
    I ENTERED A SMALL HALF OF THE PRINT PAPER AND IT WENT ON, WHILE WHEN I TRIED TO PRINT A FULL SIZED PAPER, IT GOT PAPER JAM
    HELP PLEASE, I REALLY NEED THIS PRINTER
Thanks for the tip to shake the printer upside down! I did and it fixed the exact same problem I had! Great it prints again, after eating the paper for a whole week...
Posted on Mar 14, 2009
Cut out the front or back from a cereal box, sized close to a paper sheet. Use it to push through/into the paper feed. When you press black print button, It will back out as it feeds which is normal. Black button is left of Power. Try to push cardboard right through machine as paper would travel. If it doesn't travel through after several tries, pull back out. This may seem like torturing your machine, but mine took more abuse than this and works fine again after doing this cleaned out a toothpick. Shaking the machine while upside was another solution, but be careful with the scanner lid. I felt there was nothing to lose as I was ready to buy another all in one machine.
Posted on Aug 16, 2008
    Master:
  • 638 Answers
Clean the paper feeder gears. with some rough material.it will work properly.
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Error E-3.jammed paper and there is no paper jam canon Pixma MP150
The printer needs to be opened and greased. It happened to me too.
May 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA Mp150 paper jam, how can I get the cover off to remove the jam?
open printer scaner liake as change printer cartridge open jum paper
Aug 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP150 keeps blinking E 3 saying there is a paper jammed even though there's no paper in the printer. I found a little screw inside, could this be the problem?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-5
Aug 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
PAPER JAM AND ERROR MESSAGE
20 pound is the right paper, if you can't reach the paper scrap with tweezers or anything, you should take it to a Canon shop since you have a one year warranty. 1-800-OK Canon can tell you where the nearest shop is...
Jul 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp145 error 3
it means that there is something still trapped inside. a piece of paper maybe or anything. are you sure you already remove the whole piece of the paper or not?
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error e 3 with mp150 but no papper jam
this is a paper jam,
As the machine is a old model you might as well strip the machine down and inspect it for any lose paper, it could be the reg sensor has bent causing it to always say the same error.
by the time you have tried all this i would maybe look to buy a new machine with a years warrenty from Canon
Hope this helps
Oct 09, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
121 people viewed this question
old marine
old marine
