How to connect a netgear fast ethernet switch< do i need to connect switch to dsl modem
  • 177 Answers
Netgear usually has a built in Modem.Look at your configuration settings from your manual.
Posted on Aug 13, 2008
Hi I would like o hook up a netgear prosafe 8port gigabit switch to my pc and run an ethernet cable which is allready hardwired to my sony bluray player so I can enjoy netflix
It would be much easier to use a simpler device, namely any Netgear 10/100 wireless router.
Cable-modem (or DSL-modem) --> Router's WAN port
Router's LAN port #1 --> your desktop computer
Router's LAN port #2 --> your Sony player
Router's wireless adapter --> your iPod Touch's WiFi adapter
Since the cable-modem (or DSL-modem) is only delivering 5 to 25 Mbits/second to your router,
unless you are paying a _lot_ of money per month to your ISP,
there's no need to buy/use expensive "gigabit" equipment.
Jun 06, 2011 | NetGear ProSafe GS108 8-Port Gigabit...
Can i use a wireless cable modem gateway (netgear) to make my current dsl modem connection wireless.
If your DSL-modem has one Ethernet port, then use an Ethernet cable to connect from that port to the WAN port on your NetGear router. Then, the router will provide both "wired" and "wireless" connections to your computers & devices.
Feb 13, 2011 | Computers & Internet
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Ethernet Hub EN104 Hit and Miss.
    Are you sure you got a compatible modem? They are not all alike.
    Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
    Netgear DG834G wireless router wth built-in modem doesn't connect
    Check if you have types all the configurations properly, namely Encapsulation / user name n password.
    Jun 21, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
    How to connect netgear fs108 to cable modem
    leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
    Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
    With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
    Any doubts further ? please clarify with me.... I am ready to help you....
    May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
    I currently have an AT&T Fast Access DSL modem/router and want to add a netgear wireless N router to boost the range. What's the easiest way to do this?
    The best possible configuration will be to configure the netgear router as an access point.
    The following link will be useful:-
    http://kb.netgear.com/app/answers/detail/a_id/965/kw/Configure%20router%20as%20AP/r_id/100109
    Nov 10, 2009 | NetGear RangeMax Dual-Band Wireless-N...
    Home Network Problem with Netgear MR814 and Netgear FS105
    Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
    Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
    Connect netgear wpn824 to DSL router using usb connection between DSL router and wireless router
    call your ISP. Change the DSL modem from USB connect to ethernet connect. There is no possible way two match the two device
    Dec 25, 2008 | NetGear RangeMax WPN824 Wireless Router...
    Wont connect and software cd
    To connect a router or a dsl modem to a switch you either have to use port 4 or use a utp crossover cable. As you can see on the Netgear FS605 the modem/router has to be connected to port 4.
    The correct way to connect these devices is:
    Modem > Router > Switch > Computers
    Jan 14, 2008 | NetGear FS605 (FS605SE) Networking Switch
    Computers & Internet Logo
    37 people viewed this question
    David Payne
    David Payne
