Question about Cameras
The lcd monitor is not showing any image - Cameras
  • ajswwatson Nov 04, 2008
    The lcd monitor wont show an image on my camera either. And wont take a clear picture.
  • 876 Answers
Do you also have a viewfinder? Sometimes I forget to push the little switch on my camera to go back to the LCD screen. Otherwise, please supply more info. When did this happen. Under what circumstances. Will the camera take a picture?
Posted on Aug 13, 2008
Screen shows correct image then goes black. if monitor switched off then on proper screen shows for a second then black again.
problem related to lcd lamp supply
just replace the power supply(called inverter board) connected to the lcd panel lamp
Jan 21, 2011 | Hyundai ImageQuest Q15 15.1" Flat Panel...
I have an hp\compaq presario c300 it doesn't show image on the notebook screen but i'm able to see image on the external monitor. I have replace the lcd screen and the lcd screen inverter, also made chage...
By using an external monitor, you have shown that the computer/video adapter is fine.
I'm wondering if you have told the computer to send the image to the LCD screen--using the Fn key and the special function key combo that directs the image to the LDC, the external monitor, or both.
It could also be the connection of the LCD monitor to the motherboard. You would do well to check that connection.
Oct 25, 2010 | Dell Latitude X300 Notebook
Fujitsu Siemens 19 W LCD monitor: no image
Temporarily connect a different monitor to your computer, to see if your video-card is the problem.
Temporarilyh connect your monitor to a different computer (desktop/laptop), to see if your monitor is the problem.
Try a different "data" cable between your monitor and your video-output port.
Jun 12, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
My hyundai n91s is showing bright white light but their is no computer image on the LCD
My Hyundai n92s is showing bright white light but there is no computer image on the LCD
Jan 17, 2010 | Hyundai Electronics ImageQuest N91S 19"...
Digital camera LCD monitor not working properlly
You might try pushing the DISP button with the unit in camera mode with the LCD open.
Dec 22, 2008 | Cameras
Ghosting
Does the monitor do this on all resolutions?
Try changing the refresh rate on the monitor's properties page and see if the effect changes at all.
Feb 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Compaq presario 900 lcd not working, shows faint image
out put connection from the video card to the LCD monitor is loose or malfunctioning. check the connection that leaves the video card to the monitor, ensure its secure and clean, if still not working then its either the video card or the cable connecting to the LCD.
Dec 11, 2007 | Computers & Internet
Screen Doesn't show Transparent or High Opacity Images
Calibrate in the monitor menu the RGB values to sRGB space and disable all optimizations (movie mode, text mode...). Leave it in "Normal".
Also set carefully the contrast in the monitor to something like 60% and choose the right GAMMA in the image editing software.
Make sure you are using the native resolution of the LCD and check in the user's manual how to do the adjustments because all monitors are different.
All those settings are one-time programmable, once you got the right settings they don't need to be changed again.
Sep 21, 2006 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Cameras Logo
297 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
