Question about Ovens
Whirlpool SF357PEKQ ignition issue...
I have a Whirlpool Gas Range, model SF357PEKQ. When I start the bake feature, you can hear the gas flow, the ignitor click (about 4 times) yet there is no ignition of the gas (flame doesn't start). Afterwards, both the gas flow and the ignitor "clicking" stops. There is definite gas flow (you can smell it), the broil feature works, and the cooktop works also. Any suggestions?
2 Suggested Answers
  • 47 Answers
SOURCE: We have a Whirlpool Gas
Whirlpool had some grounding issues with some of their electronic ignition ranges. Make sure your outlet is grounded first. Then you might need to make sure the bake burner itself is grounded very good against the range frame. I have put star washers between the burner and frame and tightened very tight, that sometimes helps. Also make sure the holes in the burner under the spark electrode are clear from debris. Sometimes the burning of gas leaves a residue that can stop up the holes and not let the gas flow out where the spark is hitting the burner. Hope that helps.
Posted on Aug 29, 2011
Testimonial: "very helpful, thank you for your time"
We have a Whirlpool Gas Range, model SF357PEKQ. When I start the bake feature, you can hear the gas flow, the ignitor click (about 4 times) yet there is no ignition of the gas (flame doesn't start)....
Aug 29, 2011 | Ovens
I JUST MOVED INTO A HOUSE WITH A WHIRLPOOL SUPER CAPACITY 465. IT DIDN'T COME WITH A MANUEL AND WE DON'T KNOW HOW TO BAKE. WHEN WE PREHEAT IT DOES NOTHING. THE SELFCLEAN AND BROILER WORKS THOUGH
Remove the bottom tray in oven compartment...... usually 2 screws at the rear... Turn it on to bake and see if ignitor glows if not test ignitor for 120v if you have 120v replace the ignitor. If it glows and still does not light burner after a few seconds the ignitor is weak replace it. (The gas safety valve has to receive a certain amount of power that must flow through the ignitor for the burner to ignite a weak ignitor will not allow enough power to flow through it). If you are not getting 120v trace the circuit.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Whirlpool Accubake gas stove Model SF362LXSQ. Range top is working fine Oven will not ignite. No gas smell even. When I set the oven to start I can hear the click and see the spark sometimes, but...
Iquitous, we're sorry to learn of your Oven concerns. We would like to discuss this further with you. Please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with your name, address, a phone number and best time to reach you along with your model and serial number.
Oct 26, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore gas oven; range&broiler work, not bake cycle-bad ignitor?
Well there are other parts that control the igniter,but if you can remove the igniter and look for any cracks.Most are hard to find so you may need a magnifying glass.Any crack no matter how small will keep it from glowing.The gas will not flow until the photo senser has detected the igniter glowing for several seconds.You can get a parts breakdown at SearsPartsDirect.com.Well hope this helps.
Feb 02, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
I have a Whirlpool Super Capacity 465 oven Model# SF315PEG. The bake valve was being energized but not opening to allow gas into the burner. Bought a new valve assembly P/N 3195008 and replaced. Problem...
The ignitor is not allowing enough 'current flow' to open the valve. The ignitor , even if it glows, can be 'low current' to valve.
(the ignitor current controls valve)
Sep 03, 2009 | Ovens
Whirlpool 465. The top range burners will not ignite. I can hear and smell the gas. The oven burner works fine. Do I need to replace an ignitor for the range?
The bake is seperate from the burner ignition system. You may need a new spark module for the top burners. All burners should spark at the same time even if you are only trying to lite one burner.
Aug 27, 2009 | Ovens
There is no gas going to my oven. Only the
hello, i can help you. first of all, if the broiler works then you must have gas coming into the stove. as far as getting to the gas line, it is in the rear of the stove. typically you have to pull out the stove to get to it. that said, here are some things to consider.
Not all gas ranges/ovens require electricity. If yours has a clock, electronic igniters, self-cleaning, or any other electrical features, the unit needs electricity to work properly. Check to see whether there's power getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
It won't bake If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the item takes far too long to finish, you probably have a weak bake igniter. Often, you need to replace the igniter, but you may want to troubleshoot the oven's electrical system further to more precisely locate the defect.
  • When the temperature is consistent but too high or too low, the oven thermostat or sensor is either mis-calibrated or defective. If your oven uses an electronic temperature-regulating device, you may have an electric sensor in the oven instead of a mechanical thermostat. If the oven temperature is off by 30 to 40 degrees in this type of unit, you must replace the sensor.
    On many units with a mechanical thermostat, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jun 22, 2009 | Ovens
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Ovens Logo
294 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
