Question about Dryers
Maytag dryer model lde612 runs but won't heat up. Checked the heating element and it was fine (about 10 to 11 ohms). Are there other relays or thermostats that I should check?
Hi,Check REPAIR CLINIC.COM.
Posted on Jan 04, 2009
I have a Sears dryer, model # 110.87562601.
#1 reason of dryers going bad is woman's bra's....the medal sewed in the cloth itself for support comes out and goes into the small holes and hits the heating element on both sides and shorts it out...Change the heating element....It's in back of dryer.
Oct 06, 2017 | Kenmore Dryers
Maytag Epic dryer model MED9800TQ0. Dryer was running fine, changed loads, held the start button down, it beeped and attempted to turn the drum, clicked and nothing. All the controls light up, timer...
does the element come on at this point ?
I'm not sure if you tried this already or not, but i would unplug the unit and wait a min and plug it back in and see if it resets and then works again . you could have had a power surge .
Nov 05, 2013 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Maytag dryer heating element won't come on
you should have a nominal 240 volts between the 2 heating element connections
Feb 07, 2012 | Dryers
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer isn't heating
You never mentioned if you checked the large klixon mounted above the heater.If it is bad you will have no heat but the dryer will run. If the thermal fuse (mounted on the right hand side of the heater chamber, 2 white wires) is bad then the dryer simply will not run. If it is good then the next thing you need to check is the control thermostat mounted on the blower housing. While down there check to see if that wheel is loose. If the control thermostat is ok then you have a bad contact inside the timer. Sometimes you can clean the contacts in the timer like cleaning points on a car.
Dec 10, 2008 | Maytag PYE2300AY Electric Dryer
Maytag dryer: pye2300ayw
yes, it will. you should be able to take off the panel on the bottom of the front of the dryer. way in the back is the heating element. do not put your hands in there with the power on, but start the dryer and look in there and you will see if the heating element comes on. it will be like looking inside your toaster.
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryer turns on doesnt dry
Suspect heating element or thermal fuse. The heating element and fuse can be checked with an ohm meter. The reading should be 0-2 ohms on both devices. If heating element reads infinity (nothing) replace heating element and fuse. If the fuse reads infinity then replace the fuse.
Jan 06, 2008 | Maytag Performa PAV2200
Dryers Logo
218 people viewed this question
Top Dryers Experts
