Question about Danby Heating & Cooling
In Dry and Air Condition mode, my Danby dpac 7597 is leaking from the bottom; not from the drain hose.
  • wakadooka Aug 14, 2008
    Yes, a hose was kinked.
    Master:
  • 521 Answers
There could be possibly any blockage in the outlet tube just clear that it may definately solve this.
Posted on Aug 13, 2008
    Master:
  • 623 Answers
Make sure unit is level
  • 3,037 Answers
It is leaking water correct? Check your hose for clogs or a crack, follow it up and find where it is exactly coming from. If you need a part replaced, let me know and I can find you a replacement. If you have questions about accessing parts, let me know but the outer panel should be held together with simple screws.
Not sure how to set up drainage system with air conditioning unit. Premiere DPAC 12010H After running for a few minutes it leaked water onto floor.
I find it rather amazing, that the Owner's Manual for your Model Danby unit, shows the drain hose in the parts list, but makes no reference as to how to hook it up. Since, they also make this model for Sears, under the Kenmore name.I checked the Owners Manual for it. Same thing, no mention of how to connect it. So, that leaves you just one alternative, contact Danby Customer Support 1-800-263-2629, for the answer.
In case you have misplaced your Owner's Manual, here is a link to it that your can download & print for future reference. http://www.danby.ca/cms/uploads/products/en_manual/DPAC12010H-EFOM.pdf
Hope this helps you and thanks for choosing FixYa.
Jul 21, 2011 | Danby Heating & Cooling
We have 2 Danby air conditioners. One is a Danby Designer, Model DPAC 10060 and the other is a Danby Silhouette Model DPAC 12006. The venting hoses have broken to pieces and we need to buy new ones that...
You can purchase similar hoses at most home improvement center. Take a section of the old hose with you to get the right diameter and use the existing fittings to attach them to the unint and the window exhaust. What you may find is a better quality hose/duct, than what came with the unit. You may have to buy more than you need in length, but then you'll have some left over, if you ever have to replace it again.
Hope this helped. Good luck.
Jul 18, 2011 | Danby Heating & Cooling
My Danby Premiere DPAC 13009 is leaking water through the bottom. I have attached the continuous drainage hose, and no water is going through it. I tried to manually drain the tank using the drain at the...
Water is collected from cooling mode, not just dehumidifier mode. It does not always evaporate into the exhaust stream due to design limitations.
Of course the water should never leak even on the hottest day. Two suggestions:
Try removing the hose and attaching the external tank to see if it has any effect. Otherwise, you'll need to locate the exact source of the leak.
May 25, 2010 | Danby DPAC12031 Air Conditioner
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
Probably needs cleaning. I assume it is on a level surface. Water drips from the evaporator coil into a collection tray of some type and then drains into the holding tank, this tray is either broken or the outlet is plugged.
Good Luck,
Gilsh
Nov 26, 2009 | Danby DPAC8399 Air Conditioner
Bottom Plug Leaking Water Tank Bone Dry /Everstar mpk cr 10000btu
you said that it has not been used for 3 yrs then maybe the tube leading to the water drain is clogged. try to clean it
Aug 21, 2009 | Danby DPAC8020 Air Conditioner
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
Unit does not cool with the exhaust pipe connection covered
you need to get the exhaust air out if the structure or it will never work, you can use regular duct from a supply house as a temp fix
Jun 01, 2009 | Danby DPAC10031 Air Conditioner
Leaking water; reservoirs empty
I have this too we had that problem as well, nothing we could do about it either..
i need a new hose and exaust kit you know anywhere to get that?
this unit is ancient
May 22, 2008 | Danby DPAC7599 Air Conditioner
Heating & Cooling Logo
525 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
