Question about Mustek Cameras
My camera won't turn on,Even on the charger - Mustek Cameras
  • 876 Answers
Have you tried regular batteries? Unless...is your charger plugged into a gfi outlet? if it is is the little red button on the outlet pushed in? If it is not, then the battery charger is not working. One of my chargers just went kaput, so that is also a possiblity.
Posted on Aug 13, 2008
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
My nikon d60 won't turn on
There is no fuse you can replace, the camera needs repairs.
Jan 16, 2013 | Nikon D60 Digital Camera
Won't charge
The 4100 is a camera, not a battery charger. Connecting the camera to a computer's USB port is only going to drain the batteries faster, since the camera has to use juice to communicate with the computer (even if only to say it has nothing to say).
If you're using an EN-MH1 rechargeable battery pack, you must charge it using a separate MH-71 battery charger. If you're using rechargeable AA batteries, you must charge them using an appropriate battery charger.
Sep 19, 2012 | Nikon Coolpix 4100 Digital Camera
I have a Samsung PL100 digital camera. I dropped it while at beach, it was switched off. When I went to switch it on the lens came out but then it made a buzzing sound and switched itself off. The lens is...
I had the same exact issue.... try putting it on the charger, even if you think it's fully charged... If the light is red, leave it on the charger until it turns green, and then remove the battery for a second and then put it back in the camera before turning it back on..... try turning it on. If it still won't close, put it back on the charger. If the charger is automatically indicating a red light, that means you have exhausted your battery and will nee a new one... they cost about 5-11 dollars on amazon...... hope that helps...
Jul 20, 2012 | Cameras
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
My olympus vg-130 won't turn on or charge
Try this, it worked for me:-
Obtain a desktop style charger for the LI 70B battery and charge it separately from the camera. I got a charger at very low cost on eBay. I THINK that the original camera plus original charger won't cope with deeply discharged batteries. I also suggest making sure that the Auto-Power-Down is also switched ON in future. Good Luck.
Oct 21, 2011 | Cameras
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
Camera won,t turn on or take a charge
If there is a firmware solution on Insignis-Products, you might be able to restore the camcorder to life that way.
However, if the unit won't turn on at all...even when a USB AC charger is used where it should function normally and completely...there is a problem with the camcorder and it may be bricked.
I hope this helps and I hope your camcorder isn't bricked.
Jul 07, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Cameras Logo
69 people viewed this question
Top Mustek Cameras Experts
Are you a Mustek Camera Expert? Answer questions, earn points and help others
