Question about Denon DRA-395 Receiver
Onkyo TX-28 Reciever memory function not working
The memory function for the FM tuner on my older Onkyo TX-28 is not working. It will hold the stations in memory while turned on and even if you turn it off and turn it back on. However, if you leave it off for a while it will loose the stored stations. Can I fix this fairly easily?
  • 1 more comment
  • Anonymous Dec 14, 2008
    Same problem. When I program the radio tuner presets, they disappear when the power is turned off. The presets used to work. Unit was in storage for 4 years and now presets don't stay programmed after power is recycled.
  • c_joel514 Jan 06, 2009
    The same problem is in my Onkyo TX-V940, it does not keep the preset stations, in both cases, AM and FM. It was working normaly but suddenly that function got lost.
  • JK-Minn Mar 01, 2009
    I have the same problem with my Onkyo TX-28. I think it might be a battery somewhere in the unit - I took the cover off and looked but I couldn't find it. I thought it might be using a battery like a watch battery. Worked for years and in the last year or so stopped. Thanks
  • 6 Answers
Replace super capacitor in the front board (C712) with part # 598-EDLF473A5R5C .47F 5.5V form Mouser Electronics. I did. It worked.
Posted on Feb 08, 2012
    Welcome Back:
    Visited the website for 2 consecutive days.
FOUND IT!! Memory problems on a TX28 (and others I guess). There is no battery in these units (unlike computers). The guilty part is a capacitor called a Memory Backup Capacitor. I have a Onkyo TX28 and a Yamaha tuner with the same problems. As previously pointed out in earlier postings, it is part C172 in the TX28. It is a black polarized Cap that looks like a small drum, (like a button battery actually). The refs are 0.047 farads, 5.5 volts SUPER CAPACITOR. I took mine out of the TX 28 and it shows some leakage. It is on the top part of the front-end board. Is can be de-solded from the top (no need to remove circuit board, just the top cover). It costs about a buck fifty. Order online, replace and resolder.....VOILA......
Posted on Feb 17, 2012
My TX-28 has same problem. I will fix it by tossing it and getting a much better replacement .. not an Onkyo ... I've issues with two diff Onkyo products .. not again
Posted on Jan 15, 2011
I have an Onkyo TX-SR501 reciever/home theater amp. The sound works fine in home theater mode, but no sound when FM mode selected, but fine in AM mode. Have checked Antenna.
Hi Anil, please make sure the the receiver is locked into the station. It should read FM Stereo when locked in. Thank you, Onkyo USA
Nov 23, 2016 | Onkyo TX-SR501 Receiver
Hookup eq240 to reciever
Hi Michael, you would want to connect the EQ to the Tape Monitor IN/OUT loop, Thanks, JT
Apr 19, 2015 | Onkyo Stereo Am Fm Receiver Tuner...
There is no sound coming no matter what source
Have you checked the speaker select switch on the front of the receiver? "A" "B" or "A +B" or "Off". Sounds simple, but it happens! If you still have an issue post a comment and I can help you troubleshoot some more.
Aug 17, 2009 | Onkyo TX-SR602 Receiver
Onkyo tuner
the model is at the back panel it usually starts with a TX or a T. go to or call 1-800-229-1887 were here to help.
Oct 29, 2008 | Onkyo TX-SR605 Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Fm tuner not workin in south africa
The unit will not outside the us.We have a different scan freq.
Mar 02, 2008 | Onkyo TX-SR800 Receiver
Onkyo tx 902
I have a TX-902 owners manual.
It states:
Classified Memory Function. The memory can be divided for different users or programs of stations.
How to classify stations. With this model, six classes (Class A to F) are available and stations can be memorized in any class. A total of 30 stations can be memorized in any class. A total of 30 stations can be memorized.
1. Tune in the desired station.
2. Press the MEMORY button. The MEMORY indicator will flash for 8 seconds.
3. Press the desired Classified Memory button (one of buttons A to F). The station is memorized in the selected class with the memory number which is the smallest of the unoccupied numbers in the class.
By repeating the operations above, up to 30 stations can be memorized. Any more will produce "FULL" notice.
How to cancel memorized stations:
Retrieve the class number you want to cancel and then press the MUTE/MODE button while holding down the MEMORY button. Another station can be memorized with the memory number which has been cancelled.
Hope this helps.
Nov 20, 2007 | Onkyo TX-8511 Receiver
Onkyo receiver model tx-8522
it may be muting due to a fluctuation signal. Do you have an appropriate aerial connected to the FM tuner?. a length of speaker wire pulled apart into a t shap for about 1m will do. Get a splitter and use you television antenne coscket to provide better signal for your tuner
Oct 25, 2007 | Onkyo TX-8511 Receiver
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
Denon DRA-395 Receiver Logo
1,294 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
