Question about DeLonghi PAC85 Portable Air Conditioner
Everstar model MPA08CR portable air conditioner
My unit won't turn on. Yesterday, it wouldn't turn on so I unplugged it for several hours. It then turned on and ran for couple hours then turned off. It lights up but won't turn on. Help. I really need it..... SAL
  • 9 Answers
SOURCE: Delonghi Pinguin Air Conditioner
I sat on hold with Delonghi for about 25 minutes before I talked to someone this morning.  Expect a long wait before you get helped.
For this specific problem (unit works, just doesn't blow cold air), the unit MUST be sent to an authorized repair facility.  No repair facilities in Texas.  The closest one to Texas is:
All-Brands Appliance 5008 W. Linebaugh Ave. Suite #8 Tampa, Florida 33624 813-908-2002
Delonghi said they will cover mine under full warranty up to 13-months.  No RMA needed, just a photo copy of the purchase receipt for the unit. Outbound shipping is something not covered by Delonghi, but they will pay for parts, labor, and return shipping.
All-Brands said they don't have any specific requirements for packing, other than making sure the casters on the bottom of the unit are well-protected.  It is common for them to break during shipping.  They recommended, though, that if you have someplace nearby that does professional packing, like a UPS Store, to take it there.  It's not a requirement, just a recommendation.
Along with the unit send a copy (not the original) of your purchase receipt, your name and telephone number, and the address to where the unit will be returned.  Also, include a detailed description of the problem with your unit.
I REALLY hope this information helps someone!
Posted on Jun 09, 2008
  • 1027 Answers
SOURCE: PORTABLE AIR CONDITIONER (EVERSTAR BRAND)MODEL MPA08CR NEED HELP TO OPERATE THIS ITEM
ERR - the tray full light means that it should be emptied, not filled.That tray is the condensate from the cooling process that a window unit would drip outside. Since yours is a portable unit, it collects it and alerts the user when it is time to empty it.
Posted on Jun 21, 2008
jerryg50
  • 1689 Answers
SOURCE: No water
If the air conditioner is putting out cold air, don't worry about it making water. You may not have enough moisture in the air to produce more water than it requires.
In some types of air conditioners, the water taken from the air is used to assist in cooling the condenser unit. The excess is run off.
Jerry G.
Posted on Jul 01, 2008
SOURCE: DELONGHI PENQUIN
Not sure why but un plugging and leaving of for a day seems to have reset the unit. now working fine ... for how long we will see thanks for the advice.
Posted on Aug 24, 2008
  • 6 Answers
SOURCE: where do I find parts for everstar portable air conditioners
I just purchased a 11,000 BTU Everstar from Home Depot. Not sure if it's the same model that you have. Maybe check there? I bet an employee would be willing to open one of the boxes to answer your question. Just tell them you bought it there. :) Or call Everstar, of course. Good luck!
Posted on May 31, 2009
The unit squeaks whenever turned on, no matter what level the fan is blowing (Lo, Med, or Hi). Started about a week and a half ago.
A rhythmic squeak sounds like either a fan motor bearing going bad or just vibration from the unit running thats wiggling something loose inside the unit.
Jul 23, 2015 | Everstar Portable Air Conditioner Everstar
Unit will not power up just displays E1 Any tips to get this working again.
Not sure what kind of unit you have. Try turning off the main power/unplug it. Wait 5-10 mins and then restore power. E1 is an error code but w/o more info I can't tell what it means. If you have the make/model #? Or the owners manual should tell you.
Jun 23, 2015 | Everstar Portable Air Conditioner Everstar
Everstar Air Conditioner Portable has power to unit but screen is blank, no fan or cool!!
make sure you have power to it, try using another plug if not it sound like a bad board, the boards and screens can be ordered and replaced
Oct 22, 2013 | Everstar Portable Air Conditioner Everstar
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
My everstar portable ac is not running properly. In cool mode only the fan is running if I shut off the unit and restart the compressor comes on and then shuts right off the green light blinks briefly and...
Ed, there are several things that can cause this problem, but all are solvable.
1. The current temperature setting is not low enough.
2. The air intake filter needs to be removed and cleaned.
3. The water collection tank is full and needs to be drained.
4. Obstruction in the exhaust hose(s).
Be sure to turn the unit OFF & unplug it, before attempting any service work on the unit.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 12, 2011 | Whynter Portable Air Conditioner
I have a portable air conditioner model LP0711WNR. My issue is when I drain the air conditioner, it only drains about one cup of water. Then, when I turn it back on it and use it, after about an hour it...
The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | LG LP0711WNR Portable Air Conditioner
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER MPM2 , MPM210CEBB6
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Jun 21, 2008 | DeLonghi PAC85 Portable Air Conditioner
Everstar portable air conditioner
Sep 08, 2007 | Danby DPAC8020 Air Conditioner
DeLonghi PAC85 Portable Air Conditioner Logo
169 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
