Hey, how's it going?
I was wondering if you'd got any assistance with the problem with your Xbox 360's ethernet port. I have the same exact problem.
We had a storm here and lightening struck nearby and fried our cable modem. That was easy enough to get replaced. Once we got a new one though, I noticed that my Xbox wouldn't connect to Xbox Live. It would tell me that the ethernet adapter was disconnected. I tried calling Xbox support but they were telling me my only solution was to have it sent in for repairs and that my warranty had expired.
Take care!
- Joe
SOURCE: PC Selected - Failed
Click Start, click Run, type cmd.exe, and then click OK. a. At the Command Prompt, type the following text all on one line: reg add HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\CONTROL\CLASS\{4D36E967-E325-11CE-BFC1-08002BE10318} /v UPPERFILTERS /t REG_MULTI_SZ /d PartMgr /f You receive the following message in the Command Prompt window, to indicate that this command was accepted: The Operation Completed successfully After you done that restart and download xboxxpsp2-enu.exe...and you should be good to go if your firewall ports are open 1900,10280,10281,10282,10283,10284 dup and 2869,10243 tcp good luck Restart the computer. 4. After the computer restarts, you can run the Media Center Extender for Xbox 360 application
SOURCE: Xbox 360 struck by lightening
check ur router, or have a technician look at the ethernet port
SOURCE: Blackout in my house, Xbox 360 ethernet port broken!
All the message means is it can't find the internet, so your internet must have went down.. your systems should still be working fine. I don't know much about using usb for ethernet, but that sounds like it would work no problem.
The same happend to me...I tried to generate a overheating on the console so the board resets itself but nothing happend, tried to find a solution without buy the fool expensive wireless adapter from Microsoft. Mines is connected with a Wireless-to-ethernet bridge and no modem or bridge was nock down by the lightning just my ethernet adapter...
Need help to see how troubleshooting this without sending to repair....
Cheers
