Question about Mitsubishi WS-55809 55" Rear Projection Television
Colors Colrs are distored ,a person siad i need a color gun??Is there such a thing?? Is it pricey??
  • 1 more comment
  • richless Aug 13, 2008
    Mitsibushi ws 55809
    i will try to fix myself!
    i will look into it and let you know!!
  • Mitsubishi Master
  • 8,617 Answers
You will need to replace both convergence ICs they are both STK392-570 you can get replacment ICs at the following link and they provide free instalation instructions with pictures on how to do the repair. heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 13, 2008
    Master:
  • 623 Answers
Http://61nv8.247ihost.com/mitsubishiws55809.html
  • ritchie dempacco
    ritchie dempacco Aug 13, 2008
    or just take it to local repairman
  • ritchie dempacco
    forum.ecoustics.com/bbs/messages/2/15132.html
    Master:
  • 521 Answers
Proper fault in convergence circuit get it repaired it will not be to costly.
  • 4,234 Answers
If the distortion appears to be liek a 3-D effect, the problem is within the convergence circuit. This can be easily repaired if you can solder. Please confirm the model number of WS-55809 and let me know if you wish to repair this yourself. I can provide detailed instructions for the repair.
Thanks,
Dan
    Sergeant:
    Champion:
  • 310 Answers
Model no pls..
  • khader ibrahim Aug 13, 2008
    If u r well in electronic means u can do or else better u go to the service engineer
    Check out this web sites it will help for u
    http://www.repairfaq.org/sam/tvfaq.htm
Why is my picture color distored color?????????
Your color is distorted because your color wheel is probably going bad. Try resetting all the picture values first. Sometimes they need to go back to normal when the lamp is changed. Lamps only provide white light and have no bearing on colors unless they are very dim. Also check your cables. a loose or bad cable can cause this as well. Lastly make sure your new lamp is made by Osram or Philips. knock offs wont work.
Feb 21, 2015 | Mitsubishi WD Televison & Video
Erratic colors on screen of dell laptop
most probably due to bga chip error or caliberate your monitor
Jun 01, 2014 | Dell Computers & Internet
My tv when it turns on there is no color and after a while the colors appears, also the picture is distorded, any sugestions?
Its a older set and I have fixed and even owned one---bad solder connections and or convergence problems---can you describe better what it looks like when cold?
Nov 04, 2012 | Televison & Video
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The colors are wrong...ie spongebob is kind of pink not yellow
Tries reset all colors back to factory setting,same prob.One of ur colors gun is dead,Tv have three colors guns RED,BLUE,GREEN.
Nov 10, 2009 | Televison & Video
I have a mgnavox hd t.v. and the colors are messed up
Check to see if you are using componet cables which are video cables and make sure your red ble and green are in the proper places on the reciever and the tv.
Oct 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colors are distored on screen of laptop
just check whether your RAM or display card is having trouble.if u can handle laptop hardware you proceed by yourself or else make the repair done by an expert.
Jul 07, 2009 | Computers & Internet
Cant get the redd green an blue projectors to line up correctly
you need to have the set reconverged,,,call a repairman to come out and reset the colors
Mar 01, 2009 | RCA HD52W56 52" Rear Projection HDTV
Colors on screen
Good Day, richless;
It sounds like your TV's convergence circuit has failed. This is not an easy repair for a novice, so I would recommend that you call an Authorized Service Center and have them give you an estimate.
Good Luck, big IRISH.
Aug 13, 2008 | Mitsubishi WS-55807 TV
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
Mitsubishi WS-55809 55" Rear Projection Television Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
