Perhaps resolve the reason it's protecting?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DB930-Receivers-manual/id/387bh934/t/2/
If you don't want to buy new speakers, settle for safer low volume levels.
You're going to kill that receiver driving a 3-ohm load. HTS-style speakers aren't reliably re-deployable to other electronics. Perhaps, if you have 4 speakers and they're similar you could wire them in SERIES and present a 6-ohm load to each channel.
Re-engineering the speakers themselves is, well, don't do it. It isn't rocket science but it also isn
