Question about GE Monogram ZISS480DRSS Stainless Steel
GE Monogram (freestanding) Ice Maker
Just suddenly stopped making ice. It's turned on, makes sounds but nothing.
  • Anonymous Aug 23, 2008
    i have the same problem
  • bmorris11 Nov 19, 2008
    same exact problem - anyone find the answer?
One possible problem! Right below the automatic ice maker, there is a white plastic arm that should be fanned out around 30° horizontal. Use your finger to push in and release. If that arm spring out slowly (it must fan out fast with force) then this is it. The metal spring that hook to that arm is loose! This is a V shape spring that one end hook into the plastic arm (a "L" type snap in) easy to fall out. It happened to me the first time (within 2 years) so the tech changed for free. Within a year, it happened again. This time I open the automatic ice maker out and found that by accident. I snapped the spring back to the plastic arm, and there no problem since. Good luck
Posted on Jun 15, 2009
    Problem Solver:
  • 13 Answers
Ice maker first should supply water to ice tray. then the freezer will do it's freezing then heater and ejector will finnish the job.sounds may be that of the ejector trying to dump the ice.the heater may not be heating. you ould put a knife undre the tray and feel the blade if it's hot or not. please do not put your hands under tray while in operation.
Posted on May 03, 2009
Why would my GE (model # TBX18SA) just stop making ice?
Is there any ice remaining in the slots of the ice maker? If not then the water control valve will need to be replaced. If the ice maker still has ice in the cube slots and does nothing then it is the ice maker that needs to be replaced. Here is the=> WR30X10093 Ice Maker for your TBX18SA and the=> WR57X10033 Water Inlet Valve
APPLIANCE 911
Mar 15, 2016 | GE Refrigerators
Frigidaire FRS6LR5E ice maker won't stop making ice
Ice maker wire signal arm is being held down by some item in the freezer. Move item and release wire signal arm. Any ice cubes that are frozen together over the wire signal arm. the ice rises in the ice bucket and pushes the wire signal arm up and this is what stops ice production as ice is used then arm comes down and starts ice production all over again. if there is nothing holding arm down then you will need to replace ice maker.
Oct 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
MY GE MONOGRAM ZIS420D FREZZER IS NOT MAING ANY ICE. WHAT SHOULD I DO
check for continuity on the ice maker water fill solenoid valve in the lower rear area of the refrigerator,then remove cover from front of ice maker, and there are 2 gears inside this cover,follow the instructions on the ice maker by this gear and turn it the way it tells you to,this will initiate a manual ice production,you will see the gears turn by themselves after you help turn these gears initially,then you should see water enter from fill tube in the back of the ice maker if the fill tube isnt froze over,if no ice production occurs the ice maker thermostat could be open(bad) or if it makes ice but doesn't push it out the heater below the maker may be open(bad)
Aug 12, 2012 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram fridge over freezer model has stopped making ice
water valve dripping like a faucet and making a big old ice cube in the fill tube? Ice cube hung in the ice maker? bad water filter? A wittle bit of all of the above?
MONOGRAM MANUAL
IM6 notes
Bonus
Jan 12, 2010 | GE Refrigerators
GE Monogram ice maker dispensing ice on its own
my best guess is the board in the door.try appliance parts pros.they have the best warrenty on parts.
Nov 19, 2017 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZISS480DRSS Stainless Steel Logo
227 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
