Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony KV-27S42 no sound and audio blinks four times
My Sony KV27 s 42 stop last week
timer LED blinks four rimes
I heard and check relay sound,fuse is okay getting 7.5 volt
but missisng +13/-13 V
pls help to fix these monster??
  • 10,594 Answers
+13 & -13 requires for Vertical Deflection IC and produced by Flyback Transformer, these volts will be produced IF Horizontal deflection circuit works properly. so try to check H-Out Transistor and its necessary volts / signal. Pls also mention correct Model Number to provide you more help.
Posted on Aug 13, 2008
  • Shahid Electronics
    Shahid Electronics Aug 13, 2008
    Its detail of 4 times Red-LED blink...
    * +13V is not supplied. (A board)
    * IC 541 is faulty (A board) * Vertical deflection pulse is stopped.
    * Power line is shorted or power supply is stopped.
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Red light blinks four times
Four blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 (this varies from model to model). If you have no expertise with sets like this, or this does not solve your problem, get a quote from an authorized SONY service centre - before going any further or getting the set fixed. It doesn't matter if the set is a flat panel widescreen or standard CRT model; the symptoms are similar for each and the repair costs for such will be pretty much the same.
Dec 29, 2013 | Sony KV-27S42 27" TV
Wont turn on and has 4 blinking lights
Four Blinking Lights
• On most , it means " Vertical Deflections stopped ".
and according to service manual diagnostics.
These information is for those who have knowledge
and understanstanding of electronics repair.
Level of difficulty:
• Hard : for a newbie
• Easy: for those who have tools and kniwledge
Estimated Time of Servicing
• thirty (30) minutes for a pro
• from three ( 3 ) days to week (s) for a newbie
• Check on it first, or have someone to help you
verify and troubleshoot .
thanks for choosing Fixya for assistance.
Jan 29, 2012 | Sony KV-27S42 27" TV
My sony trinitron model kv-27S42 has no picture/sound, keeps clicking and the Stand by/Timer light keeps blinking. I have disconnected it for the night, plugged it back in but the problem remains? any...
Hello
Blinking of standby light in Sony TVs are fault indications. You just count the exact number of blinks occurs at a time after switch it ON. Switch it ON and OFF by its front panel power switch, and not by the remote control handset. Do this for at least four times, count the number of blinks, confirm and inform me. I can then locate the fault section of your Tv, seometimes even to the exact point of fault too. OK
Happy New Year
Dec 31, 2010 | Sony KV-27S42 27" TV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
Try to remove the vertical IC sometimes it become Shorted causing the B+ to drop. after removing try to switch on back check the B+ if ok and the LED not blinking then change the vertical IC.
Jun 01, 2009 | Sony KV-27S42 27" TV
Sony triton kv-27s42 blinks four times won't turn on
ask rent a center to send it to their service dept in their city it will get fixed for a small price unlike some of your local tv reapair shops that will bust your head and pocket book (price) just to come take a look at it
Dec 20, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony kv-27s42 no picture no sound can here relay click
I will look up your specific model to be sure, but teh 3 blinks usually mean a power supply problem. Stay tuned for more...
Dan
Aug 23, 2008 | Sony KV-27S42 27" TV
KV-27S42 four time blinks
pls let me know, are you TV tech? or just trying at your own.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Kv24fs120 dead set with two led blinks
Two-blinks of the "Diagnostic STANDBY/TIMER LED" indicates one of two things:
1) Horizontal Output (Q502) in shorted on the A-board.
or
2) IC702 is shorted (CB board)
Two-blinks of the diagnostic red LED is a " B+ Overcurrent" problem.
The red LED will blink 2-times, stay off for 3 seconds, then blink 2-times. The cycle repeats.
The circuit board is quite delicate. One should not attempt repairs (unless one has high quality vacuum desoldering equipment such as a PACE desoldering unit).
Feb 01, 2008 | Sony KV-24FV12 24" TV
Sony KV-27S42 not on but timer flashes
The blinking light means almost 100% that the high voltage circuit has failed. Probably need a new horizontal output transistor and flyback. Perhaps an associated resistor or diode. If you have the expertise go for it, otherwise take it to a professional. In any case be extremely careful and safe. Good luck.
Jun 21, 2006 | Sony KV-27S42 27" TV
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
262 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
