Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Wondering if you got my response yesterday.
I was asked if there was a sparking sound or smell.
No sparking or smell. The chirp is like a cricket and there is no blinking light. The only light was on the pwr button.
The chirp was 17 chirps for 10 seconds if that helps.
  • Mendonca Aug 14, 2008
    The pictures on the tips and tricks site don't come up, like no longer attached. Can you describe the setup for the Phillips televeison? The things you said to move and disconnect aren't apparent in the phillips set.
  • 1,894 Answers
Really sorry. i missed to reply you among a lot of requests
well this happens do to a faulty color wheel sir.
and you will need to see for some kind of loose fittings and will have to replace the full wheel if needed.
Posted on Aug 14, 2008
I have no pic or sound except a chirping noise , sounds like a cricket , LOL , timer light stays red , there was a odor , like a burnt smell
Hello. The chirping probably indicates a shorted transistor or diode, and the burnt smell usually indicates a blown capacitor or a burnt resistor, or multiple damaged parts. I would have to see the TV to be of any further assistance. Sorry I couldn't be more helpful. Good luck.
Oct 29, 2015 | Akai PT5492S 54" Rear Projection...
Sounds like 1 million crickets are under my hood
I am assuming manual transmission. It sounds to be a clutch issue. The "chirping" noise is probably the throw out bearing. The smell may be clutch slip. It creates a kind of fowl burnt smell. Have it looked at by a mechanic to diagnose.
Jul 03, 2013 | Ford Focus Cars & Trucks
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
Chirping cricket sound
oopppsss.. time for replacement
Jun 19, 2017 | Western Digital 500GB My Passport...
TV makes chirping noise.
Power Lite LED indicator on the front panel bazel flashes?Ur power supply board is dead.Tries websites like, to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv does not power on
u have a short on one of the secondary voltages from the power supply. commonly a bad diode.
the chirp is the supply attempting to start into a short.
Dec 05, 2008 | Televison & Video
Rca modelP52936
The chirping is an indication that the power supply is having difficulty starting up. This could be a problem with the power supply itself or a problem further down that is loading the supply. For a set this size, I'd invest in a detailed repair estimate. Report the results here and we can walk you through the actual repair.
Sep 10, 2008 | Televison & Video
Chirping and not coming on
Replace the defective Convergence
Amps (7044 and 7045) on Small Signal Module.
Aug 12, 2008 | Philips 51PW9303 51" Rear Projection...
Same Deal-Cricket beeping sound when plugged, Dead TV
The chirping sound you hear is normally the regulator circit trying to start up. It needs a signal returning from the high voltage transformer to turn it on. The reason the regulator cicuit is not working varies: The horizontal output is shorted, usually caused by a bad transformer in this model. The focus block goes out in this model quite a bit. The secondary of the power supply may have a missing voltage. I have found that there is no horizontal pulse coming from the drive circuits. Sometimes the regulator circuit itself has an issue. Either way, there are so many problems that can cause the regulator to chirp, diagnostics may be tricky.
Apr 15, 2007 | GE 46GW947 46" Rear Projection Television
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
