I have NetGear set up for my desktop computor which works fine, no problems. I bought a Advent laptop and again was able to get online via the netgear until a few days ago when for no apparent reason I lost conection and just get the message that DNS sever not found. I've tried switching everything off and on again without luck, can you help please Mistired
    Problem Solver:
  • 35 Answers
Reset the router. there is button on the back. hold it for 10 secs or till you see the lights blink. then try again. make sure that you set the password etc
Posted on Aug 13, 2008
SOURCE:
Router setup
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
You can do it manually without the CD.
Click Here for step by step by instructions
Jan 28, 2010 | NetGear WGR614 Wireless Router
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
I have a NetGear Wireless Router which wont connect to internet.
Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
Aug 30, 2009 | NetGear RangeMax WPN824 Router
Advent 4213 netbook not connecting to wireless network
Have you entered the security details regarding your network connection into your new netbook.
Sounds like the problem.
Detect the network and enter the security key (WEP;WAP etc) and should work
Jul 11, 2009 | Computers & Internet
I am unable to get my Dell Laptop online anymore.
I can solve this for free so don't worry about the money. We may have to go back and forth a few times so get a pen and paper, cause I can't see what you see. And I'm gonna send this in as a solution but you don't have to rate it until you are satisfied. That way is will be just you and me working on the problem and there won't be any conflicting information.
Alright, you say that you have a connection to the wirless router with your laptop but you can't get on the Internet on your laptop. So do this first and send me the info. First, click on start>run>type in cmd. This will bring you to the DOS prompt. Type cd \. Now you should be at the C:>.
Type in ipconfig /all. Then send me the IP address (should be 192.168.xxx.xxx.) and the gateway address (xxx.xxx.xxx.xxx). We'll start from there. I have to see if you are connecting to the ISP web server. Just send it and I'll reply.
Jan 18, 2009 | Dell Latitude D600 Notebook
Problems connecting my laptop to wireless router
Make sure that you do the setup via cable, not through wireless!
If you change form WPA to WEP, the length of the key changes and you will have to provide this new key if you want to connect wireless to your router.
You can leave your laptop connected via cable and check if your wireless card can connect.
No, you don't have to reinstall everything again. Just plug in the cable, connect to your router (192.168.x.x) and check your wireless setup.
Dec 28, 2008 | NetGear WGR614 Wireless Router
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
HAVE INSTALLED NETGEAR DG834PN, WORKS WELL WHEN CONNECTED DIRECT TO LAPTOP, BUT WILL NOT CONNECT WHEN UNPLUGGED FROM COMPUTOR
  • Your laptop has to be configured with the wireless settings set in the router.
  • In your laptop, you may check the available wireless network that it can detect and you must select your own wireless network.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Wireless routers
Just plug the cable modem ethernet into the input to your router and you will be fine. Just remember, if you decide you want to make any changes to your router settings through your browser, make sure you hook up an ethernet line from your laptop to the router before making any changes. The reason for this is if you make a change in security settings on your router while wireless, the router will reboot and if your laptop did have the settings changed in it, you can be locked out.
Not that you can't get back in, but it is a pain to have to do.
Jan 14, 2008 | Arris SURFboard SB4200 Modem
Open Questions:
Roadrunner Email Number*1^855+536+5666$#%*& Roadrunner Email support number Roadrunner Email is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Roadrunner Email email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Roadrunner Email support number When you are using the Roadrunner Email for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Roadrunner Email support number and ask for the help. Once you dial the Roadrunner Email customer support number, you come in contact with a team of experts at the Roadrunner Email customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Roadrunner Email support phone number will help you with that simply and quickly. This is Roadrunner Email's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Roadrunner Email agent. Features of Roadrunner Email support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Roadrunner Email customer support phone number. Here are some of the features of customer service: The Roadrunner Email customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Roadrunner Email customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Roadrunner Email provides you the facility of Roadrunner Email support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Roadrunner Email. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Roadrunner Email Customer support number team.
Oct 18, 2019 | HIS Computers & Internet
Computers & Internet Logo
46 people viewed this question
Ekse
Alun Cox
