Question about Copystar Ri-2530 Printer
Jam & Customer Service
On our company's copystar ri-2530 there were two paper jams on the side. I was able to fix those just fine, but now suddenly the screen has flashed up saying to call customer service. I tried to turn it off of course and turn it back on to see if it would go away but it is still there. Do I really have to call customer service, because there is nothing that seems to be wrong.
  • 523 Answers
Hi, Actually if the machine still working fine you donot need to call for service, all wat you want to do is to clear the service from the machine, here wat happen, there was an error in ur machine , the sensor report this to machine memory, but you fix this problem and the sensor didnot regonize this is solved, so you have to reset the service of the machine and you will be fine.
Wat i understand it says just call for service is there is any code with this message?
if not donot worry
hit on the touch screen 1087 twice, this will take you to maintenance mode, scroll on screen to see reset the service, highlight it and hit the reset buttom and u will be fine.
Let me know wat happen.
Best Regards
Posted on Mar 02, 2009
Attach finisher
check if the microswitch on the finisher right side is broken,
the locking bracket attached to the copier left door has to engage
this switch to turn off attach finisher error
Mar 27, 2014 | Copystar Ri-2530 Printer
Replace the waste toner box
Please write me your copier brand name and model name.Some times when waste toner is full the tank than show massage replace the waste toner box.You should clean the waste toner than fix this massage.
Oct 20, 2013 | Copystar Ri-2530 Printer
He asks the photocopier Copystar Ri-2530 Printer It is possible to form to stamp I him do not see connections
Okay, please reread your question because as I read it, it makes no sense to me.
Who tells it to form for stamp and what does that mean? Does the printer have a font or application that will print postage on the envelope?
Oct 15, 2010 | Copystar Ri-2530 Printer
Copystar CS-C2525E. Paper Jam error 91. No paper
Under included device open and close the lid. Unless throw, see the condition a sensor entry and leaving the paper - can be the sensors conk. Good luck
Oct 06, 2009 | Copystar CS-4035 Copier
It prints black line down paper
usually caused by something in the paper path after the
print head, or the print head. Cleaning the surface of the print head with a
lint free damp towel may cure the problem.
or for our technician help call us at our toll free no 18884276640
Jun 23, 2009 | Copystar Ri-2530 Printer
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Copystar Ri-2530 Printer Logo
89 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
