Open following link for Hagar timers:
http://waterheatertimer.org/Hagar-timers-and-manuals.html
Hagar EH711 has segments located around the analog dial.
The dial rotates as time passes and the segments move tiny lever that turns Loan on-off.
The segments are pushed down and outward or up and inward to set on-off times.
The timer can be wired a couple different ways, so setting the segments up or down depends on how it was wired.
If you look at dial on your timer and see how segments are set now, that will give you the correct information.
If segments are down between 7:30am and 7:30 pm, then move those segments up-and-inward.
To check the timer after moving your segments, you can manually rotate dial clockwise and watch the load turn on-off. To set current time, rotate dial until current time lines up with arrowhead located on inner dial.
The slide switch has 3 positions. 0 = ON all the time; 1 = OFF all the time, and Auto = timer turns on-off depending how segments are set.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
