Question about Frigidaire FEF352 Electric Kitchen Range
Lock won`t open
Lock came on after door was open, lock won`t close now
  • 258 Answers
Look for a button or sensor which turns the light off or which the door would press when closed.
If you find it hold it down for a minute, then let go this should reset the lock
Posted on Jan 18, 2009
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Film camera back door won't close
Does it not close or does it not lock? If it does not lock it may be the light seals are obstructing the door. If it will close but not lock open the camera, pull up the rewind knob, see if the release slider is operating.
Jun 28, 2012 | Pentax K1000 35mm SLR Camera
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Oven door will not fully close allowing heat to escape and light stays on
Is the door locked? if it is it won't close all the way if it was in the locked position before it was closed. like if it was programmed for "self clean" without the door being closed, the lock would be engaged still.
Jun 09, 2012 | Electrolux EW30ES65GS 30" Slide-in...
Door ajar light on and locks keep locking and unlocking
need to gain access to the BCM to see which door the module is seeing open. the locks won't lock with key in ignition and a door is "open"
Jun 09, 2012 | 1997 Chrysler Town & Country
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Back door won't close
you can check the lock on the door isnt in the closed position(would sound like banging noise)
with the inner door handle pulled see if you can flip the lock to open on door. lubing doors once in awhile will prevent this
Jun 17, 2011 | 1996 Oldsmobile Cutlass Ciera
Frigidaire FEF352 Electric Kitchen Range Logo
224 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
