Samsung S3500i Cell Phone Logo
Posted on May 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want samsung default reset pin for reset setting..
Anonymous
Level 3:
President:
  • Master 287 Answers
  • Posted on May 14, 2011
Anonymous
Master
Level 3:
President:
Answers
287
Questions
Helped
209772
Points
1267
Hello and Welcome to FixYa!
If you haven't changed
reset pin code before then Default reset pin code for samsung is 00000000 (eight zero's)
I hope it works.
For further assistance i am here to help.
Thank you for using FixYa!
Concerned: Angel Bird
How do I reset the PIN Number on Samsung BD-H6500 Blue Ray DVD please?
Question edited for clarity and order, 'make model (what it is)' and toss in some CAPS.
Question moved from Cellphones to make model category.
https://www.manualslib.com/manual/834092/Samsung-Bd-H6500.html?page=50
Reset. ALL settings will be reset.
• When the factory default settings are restored, all stored user BD data will be deleted.
• factory default settings are restored, all stored user BD data will
be deleted.
• Press the button Eject (on top panel) for more than 5 seconds with no disc inside. The initialization message appears on the screen, and the player turns off automatically. When you turn your product on again, all the settings will be reset.
Don't use this unless absolutely necessary.
How to Reset a Samsung Blu-Ray Player - Support.com
Support.com https://www.techsolutions.support.com > how-to > ho...
1 Factory Reset · Make sure there is no disc in the player. · Press and hold the Eject button on the device for at least 8 seconds. · On the screen you will see a ...
How to factory reset my Samsung smart TV
Navigate to Settings and then General. Select Reset. Enter your PIN (0000 is the default) and then select Reset. To complete the reset, select OK
2answers
I want to reset the Samsung ezon shs5120 password
Reset master Pin Samsung EZON Home Systems shs-3120? How do i reset the master Pin for Samsung Ezon Touchpad Door Lock SHS-3120. I tried to follow instructions written in the user manual but it doesn't work. I have forgot master PIN and factory reset for deleting all the users(as mentioned in manual) and setting the master Pin to default value of 1234 is not... show more
Update: I found the answer/solution
1. Press Initalizaion button on the indoor unit.
2. Press Set button for 10 Seconds.
3. Input the code "1470852369"
4. Press * Button.
Then password will be changed to 1234
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
How to hard reset Samsung 55UES7000
default is 0000
To perform a Factory Reset, follow these steps:
  1. With the TV powered on press the MENU button.
    1. Use the Up arrow-up_15x13.jpg or Down arrow-down_15-x-13.jpg arrow buttons to select the Support section of the Main Menu, and then press ENTER.
      1. Use the Up arrow-up_15x13.jpg or Down arrow-down_15-x-13.jpg arrow buttons to select the Self Diagnosis option, and then press ENTER.
        1. Use the Up arrow-up_15x13.jpg or Down arrow-down_15-x-13.jpg arrow buttons to select the Reset option, and then press ENTER.
          1. Your TV will require you to enter your security PIN. If you have not set up a PIN the default is 0000.
            1. A factory reset warning will appear, you can cancel the reset at this time by selecting No.
              1. The TV will power off and when it is powered back on the Setup screen will appear.
Master reset proceedures
Reset Settings
Use Reset Settings to return all settings to their defaults.
1. From Standby mode, tap Menu Menu 1 Settings Phone
Settings Security.
2. At the Enter Code prompt, enter the lock code. By default, the
lock code is the last four digits of your phone number.
3. Tap Reset Settings. At the prompt, tap Yes to confirm the reset.
To keep your current settings and return to the Security submenu,
tap No.
or
Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Need to reset phone
don't think you can unless you take it a teck shop and get it restored to factory setting (default 0000)
6helpful
2answers
What is the default security code and PIN for
Default Security Code - 00000000 or 0000
Regarding PIN, there is no default PIN set up by Samsung. If you wish, you can select a PIN for your handset. The procedure is :-
PIN (Personal Identification Number) code' is a security tool designed to stop unauthorised usage of a SIM card. You can set the PIN code on 'Security Settings'. You will then be required to enter the PIN code every time the handset is turned on.
Hope i helped you.
Thanks.
Sep 07, 2009 • Cell Phones
1helpful
Samsung E900
do *2767*3855# this will reset the phone for you
2helpful
Samsung D900i pin number
Bro original code inside samsung phone default is 00000000. But it is possible somebody had change it. After full charge battery without simcard enter string *#2767*3855# and your phone will show reseting E2P and other instruction. Follow that and your code will change to 000000000(default company code). It works don't forget to vote reply...
Jan 05, 2008 • Cell Phones
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
