Question about Sharp R-420DK Microwave Oven
Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
My microwave (Sharp R-420BK) has worked fine until I moved it, recently. Now the clock display is "messed up". There are numbers, but they don't display correctly. It is as if some of the lights on the clock display don't work, making the numbers display incorrectly. The touch pad works fine. The microwave heats just fine. Everything else is perfect except the digital numbers don't display correctly. Do you know what I need to do to fix it, what part I would need, and if the repair is even cost effective for this model microwave?
  • Sharp Master
  • 9,086 Answers
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
I have a 12yo Sharp r-430cs microwave. The LED is not displaying all the "lights" in the numbers/alpha readouts. It is missing a lot more of the readout than it is showing. Everything else is working
Go to Sharp's website and check availability of the clock/timer readout board. Being that old you may not be successful, but it;s worth a try.
Oct 21, 2014 | Sharp Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    LCD pad, numbers do not appear clearly but as a distorted image. example 1:10 may appear as blank.1E example .40 may appear as blank.1L microwave works fine just the read out panel is distorted,...
    On most recent Sharp microwaves, the fuse only interrupts main power, so if the fuse is blown, it will be totally dead.
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for about 5 minutes then try it.
    Then chances are you have a failed microwave display. Unless this is an over the range, touch screen, or convection type, it's probably not worth repair, but you can get more information on such repairs here.
    Jan 15, 2011 | Sharp R-310CW 1100 Watts Microwave Oven
    No Heat but everything else works
    Magnetron and diode most likely. Need more info.
    Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
    How to set clock on sharp microwave
    normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
    Sep 21, 2009 | Sharp R-1480 Microwave Oven
    The clock works & counts down but the microwave won't heat
    • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
    • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
    Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
    Aug 03, 2009 | Sharp R-1460 Microwave Oven
    Sharp R409AK microwave, no digital display or clock
    We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
    In my professional opinion, these problems are due to weaknesses in both design and manufacturing.
    Our proprietary repairs and modifications are designed to correct and prevent such trouble.
    Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
    William E. Miller, AS-EET
    prototech@usa.net
    Jun 08, 2009 | Microwave Ovens
    My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    fggfd
    Sep 22, 2008 | Sharp R-1610 Microwave Oven
    Sharp R-420DK Microwave Oven Logo
    496 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
