Question about Cameras
I HAVE A CANON AND WHEN I TRIED TO PRESS THE BUTTON TO TAKE THE PICTURE IT SEEMS THE SHUTTER GOT LOCKED AND COULD NOT USE THE LEVER TO TURN TO THE NEXT PICTURE. I THOUGHT MAYBE IT WAS BATTERY NEEDED SO I REPLACED THE BATTERY AND STILL IT WILL NOT UNLEASE - HELP
  • 35 Answers
Film camera I assume?
Sounds like the end of the roll to me or it may be off track.
Remove and replace film with NEW roll. While its empty (and open) you might try the shutter release button and watch the shutter (it is very fast so hold it up to light) to see if it is working.
Posted on Aug 13, 2008
SOURCE:
When I press on the shutter button there is a whirling noise and the camera will not take a picture.
Have you tried cleaning the contacts on the lens/camera?
Is the lens free from obstructions?
Jan 07, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
This analogue AL-1 Canon camera do not take a picture when pressing shutter release button. I guess it is because the button to the wheel located inderneath is stuck for some reason. Can I fix this myself...
From your video I can't tell whether the shutter is cocked. Can you crank the film advance lever all the way and then press the shutter release button?
Apr 03, 2013 | Cameras
Cannon EOS500D, taking a picture in creative modes I have to press the shutter button twice to take a picture.(not counting the half pressing of the shutter button. the second pressing of the shutter...
Hi kevinmullen8 - was this ever resolved? My mum was mucking around with my camera (eos1000d) and I have the exact same problem (press shutter twice in creative mode). Factory reset was of no assistance.
Please help!!!
Dec 05, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
The shutter on my canon a-1 seems to be stuck. After I wind up the film, nothing happens after I press the shutter button. I opened the bottom of the camera up and pressed the L-shaped lever and magnet to...
If you opened the bottom you saw the magnet that holds the shutter /mirror mechanism closed- sometimes it and the lever it holds get dirt or corrosion on them and won't hold the lever when you **** the shutter? it can also be the battery is not dead, but not enough voltage to supply enough power to hold lever.
Aug 24, 2009 | Canon Photography
Canon A-1, film advance lever and shutter release
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jun 24, 2009 | Nikon FA 35mm SLR Camera
Ok-- I would say it's fixed, but it's not
Ok, I'll break it down for you. Look down on top of the camera. On the right hand side, there is the shutter button. Just to the left of the shutter button is a small lever. It is between the shutter button and the camera...but it's part of the shutter button. Move the lever to turn it on and off.
Mar 04, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Hi, I have a Canon Power Shot S2 IS 5.0 megapixels that was working fine until one day I changed the memory card from 512MB to a 1GB. Now every time I turn the camera on and try to take a picture, a...
Its possible that there may be an error on the camera try to reset the camera by
1. Turn the mode lever to the camera or play button
2. Press and hold the MENU button for more than 5 seconds.
3, The message "reset settings to default?" appears
4. Use teh arrow buttons to selelct ok. then press the SET button.
5. It should then reset the camera.
AFter doing that and the problem is still there. Format the memory card using the camera.
I hope this has answered your question sufficiently. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 06, 2008 | Canon Cameras
Video Problems
Auto Mode In this mode, all you have to do is press the shutter button and let the camera do everything else. 1. Turn the camera on.
2. Turn the shooting mode dial to normal_mode.gif.
mode_dial.gif 3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
  • The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
  • When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
  • Two beeps will sound when the camera has finished metering, and the indicator will light green or orange. If the LCD monitor is on, the AF frame will appear green.
  • The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
af_frame_indicator_a70.gif 6. Press the shutter button all the way.
  • You will hear the sound of the shutter when the shutter activates.
  • The picture appears for two seconds on the LCD monitor, if it is on.
  • The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
Jun 10, 2007 | Canon PowerShot A400 Digital Camera
Cameras Logo
70 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
