Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Water won't drain thru
When washing machine spins water don't drain thru house pipe fast enough, because it spill out on the floor
  • 125 Answers
You need to clean the drain pipe, maybe draino or call a plumber to snake it out.
Posted on Aug 22, 2008
Washer pump makes a clicking sound and is not pumping water fast enough before spin cycle, witch spills the water that was not pumped out. could the pump hve somthing blocking it ,or is the pump strti
Hi, there is most likely a blockage. Common is the coin blockage, locate the drain pipe and disconnect from area nearest to pump, usually has clamp fastening on either side of pump, disconnect both sides and check for foreign objects. Important*** disconnect machine from main current supply before working to avoid a shocking experience***. Hope this helps.
Apr 18, 2014 | Washing Machines
My washing machine has two flashing lights and it want drain the water it just stops half way through i think my water pump is broken
machine wont spin while it has water in my advice is to lay the drain pipe level with the floor (outside of your house) so it can drain if it doesn't drain then you have a blockage anywhere from the drum outlet into the pump to the water pipe if it does drian then take the pump apart and check it turns freely
Jun 04, 2011 | Washing Machines
Machine will wash but not drain or spin.
machine wont spin while it has water in my advice is to lay the drain pipe level with the floor (outside of your house) so it can drain if it doesnt drain then you have a blockage anywhere from the drum outlet into the pump to the watse pipe if it does drian then take the pump apart and check it turns freely
May 30, 2011 | Washing Machines
Is leaking water at the back and running in the floor the hoses are tight drain pipe is in right
Here's what I've seen. Water will be full, machine goes to spin/drain and expects the water to be pumped out as predicted. If pump is clogged, the pump cannnot pump out water quickly enough and the spinning causes the water to spill over the back of the tub, between the tub and balance ring. The balance ring is never sealed tightly to the tub so water will get through. Fill the basket with water, extra high, hold lid switch down, and see if it drains out fast enough so water doesn't spin out. If this is the case, pull pump, dislodge debris.
Oct 02, 2010 | Maytag Washing Machines
The hose that drains the machine is spilling out water. Is there some kind of blockage in the line caused by detergent??? The plumber snaked the line but water is still spilling out of the drain pipe.
is the hose in the washtub?  It's not laying on the floor is it ??  if it is, it has to be 36 - 42 inches off the floor or water will just go in and out...
Jul 28, 2010 | Kenmore HE2 Plus Front Load Washer
On one wash clothes came out sopping the next there was no water
Check the drain hose for kinks or blockage. The drain hose should be free in the drain pipe so air can get around it. The drain should be good enough to accept a lot of water all of a sudden without overflowing.
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Rinse pipe overflow
Depending on how your drain system is plumbed where you live.. many homes use a 'trap' .. meaning a place where water remains to keep sewer gas from getting back into your home.. If your house is set up with this ( and it may be on the wall or in the floor).. you may have a blockage there that won't allow water to drain fast enough and the pipe fills up and leaks onto your floor.. Hope this helps you...
Sep 24, 2008 | Washing Machines
My new Front Loading washing machine has a terrible mildew problem!!!! I have used clorox bleach, lisol, clorox spray cleaner and the problem goes away for one load. If a new load sits for more than 30...
your drain where the hose drain hooks to your house isnt draining fast enough ,there must be lint in the pipe ,when your washing machine pumps out the water the pump shuts off ,but the drain hose is syphoning the water that the drain pipe has in the pipe back into the machine
Jul 08, 2008 | Whirlpool Washing Machines
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
