Lexmark 9500 fax trouble
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I am using WINXP Sp2. I recently added a lexmark 9500 all in 1 printer/etc. I can not get the fax option to install/function. The message says "the fax driver is missing. you must un-install and re-install the software" I can't figure out what this means or wants. Any wisdom out there? Terry
    Brigadier General:
  • 6,966 Answers
Pls try:
  • un-install the 9500;
  • reboot your PC with the Lexmark's USB connection;
  • preferably clean your registry;
  • reboot again;
  • temporarily disable your antivirus and firewall;
  • use the CD installer that came with the Lexmark 9500 and do a clean fresh install. Do not plug in the printer/fax until instructed to do so. Pls follow on screen instructions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 14, 2008
  • Louie  Role
    Louie Role Aug 14, 2008
    The message that says "the fax driver is missing. you must
    " simply means that even if you popped in CD and went through the installation procedures, the software did not really install. Most likely it was prevented from installing and chances are, it is your antivirus and/or firewall.
Lexmark 9500 accepts and prints incoming wont send faxes...help
Check if you're using the correct dialing rules (if you need to dial 1 before the number). Also, try to decrease the transmission speed. To do that, on the control panel of your printer, press the down arrow until you reach Fax > Fax Setup > Dialing and Sending > Max Send Speed > set it to 19600.
Oct 30, 2012 | Lexmark Office Equipment & Supplies
I have a Lexmark mode lX3550. What do I have to do to make it fax?
Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. • The Lexmark Fax Software is installed on your computer.
Sending a fax using the software You can scan a document to the computer and then fax it to someone using the software. 1 Load an original document facedown on the scanner glass. 2 From the desktop, double-click the Lexmark Imaging Studio icon. 3 From the left pane of the Welcome screen, click Fax. 4 Select the Document option. 5 Click Start. 6 Enter the recipient information, and then click Next. Note: A fax number can include up to 64 numbers, commas, periods, and/or these symbols: * # + - ( ). 7 Enter the cover page information, and then click Next. 8 If there are any additional documents that you want to send with your fax, add these now, and then click Next. 9 To send your fax: • Immediately-Select the Send now option. • At a scheduled time: a Select the "Delay sending until" option. b Set a time and date. 10 If you want a paper copy of your fax, select Print a copy of your fax. 11 Click Send.
Aug 11, 2011 | Lexmark X3550 All-In-One Printer
Trouble getting printer to print for first time after downloading the driver from the internet. Mac OS 10.4
Try to delete the Lexmark Z715 print object from the Print and Fax on your Mac 10.4. Then, add a new Lexmark print object. After successfully adding a print job, try to print a document again to verify that printing is working properly now.
Aug 08, 2011 | Lexmark Z715 InkJet Printer
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
X9575 phone conflict
You may have wired your FAX and Phone up wrong. Go to the following website to view the Manual and try going to page 28 and try wiring it up again.
http://www.lexmark.com/publications/pdfs/2007/9500/winug/en/lxdouser.pdf
Thank you for using Fix Ya!
If you still have questions, let me know.
Don;t forget to rate the overall satisfaction of this solution.
Feb 19, 2009 | Lexmark X9575 InkJet Printer
Failed to Create print object
Step 1: Click Start --> Printer and Faxes --> Add a printer.
moz-screenshot.jpgStep 2: While wizard appear, click next and tick on A network printer or a printer attached to another computer. Click next.
Step 3: On the specify printer options, tick Connect to a printer to the Internet or on a home or office network. Specify your printer destination. Example: http://192.168.110.120/
Jan 30, 2009 | Lexmark X945E Printer
Lexmark 5495 Fax Problem
Go to Start->All Programs->Lexmark 5400 Series and launch the Lexmark Fax Solutions.
Click on the Tools menu and select the Adjust Fax Settings option.
See if there is anything in the Dial prefix.
Steve
Nov 03, 2008 | Lexmark X5470 All-In-One InkJet Printer
Sharing with Samba/Cups
To my best knowledge, you cannot. The drivers and scanning software on your unit are not designed to support network protocols. Your unit does not come with an Ethernet adapter and it is not available as an option. When Samsung fits an equipment with a network card (such as the SCX-4521FN) the drivers and software are enabled for network use. By the way, your toner will only last for 3,000 pages. Are you sure it's a good idea to share such such a small unit over a 10 PC network?
Sep 25, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Nozzles trouble for brand new jet spray print cartridges.
YOU MAY USE A CLAEANING SOLUTION ,TYPICALLY A HYDROGEN PEROXIDE SOLUTION FOR A FEW MINUTES AND THEN CLEANING WITH A BLOTTING PAPER AND GIVING FEW JERKS TO THE CARTRIDGE, ----A RAW SOLUTION,BUT WORKS EFFECTIVELY HAPPY FAXING
Sep 24, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
384 people viewed this question
jasbo
jasbo
