Question about Haier HWR06XC5 Wall/Window Air Conditioner
The haier is freezing up we bought it last year and its already freezing .. we cleaned the filter and dont know where the evaporator is but no cool air is coming through alot of ice on it though
The hair is just on its second summer and it just freezes non stop. we cleaned the filter and not sure where the evaporator is on it but it wont cool off please help child home and need to keep the house cool due to her condition....
Unit is freezing over and i just cleaned it
Posted on Jul 19, 2009
My haier A.C portable unit is freezing up
Hello, the unit will freeze up from one of two reasons...either a low refrigerant charge due to a leak or the evaporator coil is dirty and must be cleaned with a coil cleaner.
May 03, 2012 | Haier Mechanical Air Conditioner HWF05XC7
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
I have a Haier ESA406K 10,000 BTU's that just
sounds like you have a small refrigerant leak which would at first result in the evaporator coil freezing over, then eventually not working at all.
Jun 11, 2011 | Haier Heating & Cooling
I bought my Haier HWR 10xc6 mid summer of last year. Used it for two weeks and it was fine. Didn't use it much as went out of town the rest of that summer. I turned the unit on last week and set the...
Hello, it can be a few things. 1) plugged air filter and evaporator coil 2) low refrigerant charge 3) the compressor is not engaging If you are willing to check out a few things i can tell you exactley whats going on with your ac
Jun 07, 2011 | Haier hwr10xc6 Air Conditioner
The unit is freezing up and leaking alot of water
Hello, first thing is check the condition of the filter on the front of the unit, if it is dirty wash it and let it dry then reinstall it. Also, it is a good idea to clean the evaporator coil with a can of coil cleaner that you can pick up at any heating and cooling store. Just spray cleaner on evaporator coil and let it dry. If this does not solve the problem tjen the unit might be undercharged and will need a hvac tech to recharge it
May 04, 2011 | Haier HWR06XC9 Air Conditioner
Why is my air conditioner freezing up?
The most common reason for an air conditioner to freeze is a clogged evaporator coil. Check and see if the filter is clean If yes then pull the unit our of its case and use the garden hose to clean it out. If it freezes after all of these steps it likely needs a shot of refrigerant.
Jun 27, 2010 | Haier ESA306 Air Conditioner
Window A/c 10 or 15 days is good working\r\nbefore !0 or 15 days ago all Eveporater and section line freeze fan moter good praper work melt the freeze and A/C on A/C giving good cooling what is problem
Hello
You may try cleaning the evaporator filter,Also cleaning the outside coil or condensor,Simple green works good for cleaning coils and a garden hose.
Also cleaning the evaporator may help.
When unit is running properly the evaporator should feel cool and wet from top to bottom.
Last,the unit could be low on freon.
Jun 10, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Haier ac unit keeps freezing in the front where the filter i located how do i prevent this
Freezing is a bad sign... but dont give up yet...
these are the signs that will cause freeze up...
dirty filter
t'sat not shuting off
cooling a room too big for the unit
settings at max but room is still hot
and the worst case... a/c leaking freon..
the leaking part is bad cause if you get someone to put it back in next year (or sooner) you have to call em back to recharge it again...
if everything checks out then it is the leaking freon... throw away...
what you pay $100 or so???
hope this was helpful
Apr 05, 2010 | Haier Mechanical Air Conditioner HWF05XC7
No longer cool
If the unit is operating normally but not cooling properly than you are low on refrigerant.
Oct 01, 2008 | Haier HWR06XC5 Wall/Window Air Conditioner
Ac ices over
First you need to make sure the filter is clean to allow good air flow through the evaporator. If the filter is clean make sure the evaporator is not plugged up with dust and lint. If all that is ok your problem is the a/c BTU's is to big for the size room you have the a/c in and it is getting the room too cold. If that happens the evaporator will ice up and will not cool the room.
Jul 08, 2007 | Haier HWR06XC5 Wall/Window Air Conditioner
Haier HWR06XC5 Wall/Window Air Conditioner Logo
326 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
