Question about Daewoo KOC-925T Microwave Oven
Light bulb changing
I have been a mechanical electrical engineer for just under 30 years and am blowed if I CAN FIND A WAY TO GET IT OUT I think it is on the control panel side but when i remove the small fibreglass panel I can feel the bulb on what is like a chute no way will it turn,push in or anything else.Seems mad where it is but you can just get a finger and thumb upto it.
Any ideas?
Yours
ERCADRAH
  • Daewoo Master
  • 9,086 Answers
That mica panel is the waveguide cover, and what you're feeling in there is the magnetron antenna.
If there's no other removable cover inside the cooking cavity, (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 18, 2008
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Unplug the Magic Chef microwave from the wall outlet.
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
I have a mh1150xm microwave and changed the cooktop lightbulb. Still no light. A tech came and said that need to change whole control board. Is this true. Everything is working fine exept the light
I take it you did replace with a bulb designed to withstand heat.check the filament of bulb first these sometimes get damaged in transit.if the microwave is coming on then it won't be the fuse.if the bulb looks okay(you can check using another) finally inspect the door latch and the bulb housing and wiring to it.Sometimes door latch hole can get debris into the mechanism.cost of panel via engineer can cost quite abit..is it still in warranty? Price compare the estimation against buying new replacement.
Feb 09, 2015 | Whirlpool MH1150XMQ Microwave Oven
Mco 153s can not find how to access oven light for replacement there does not appear to be access from above under filter no door solid metal only
On page 20 of your owner's manual:
To replace oven light:
1. Disconnect power at main fuse or circuit breaker or pull plug.
2. Remove the top grill by taking out the 2 screws that hold it in place. (See Figures 3.)
3. Remove charcoal filter.
4. Pull out the Lamp cover. (See Figure 4.)
5. Replace the light bulb with a 30-watt bulb.
6. Replace light housing to original position
7. Replace charcoal filter.
8. Replace top grill and secure with screws.
9. Connect electrical power.
Aug 10, 2013 | Magic Chef Over The Range Microwave
Lights on bottom don't work. Sockets fell apart and vent fan now does not work. A bulb blew out , then all of this happened.
We see and repair this a lot. The problem is on the control board, which we regularly repair for $39.95 nationwide.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
We'd also recommend buying top-quality bulbs.
They can blow if subjected to vibration such as door slamming or a weak floor, or electrical fluctuation, especially if they are cheap bulbs or they are left on all night.
Instead of having the board repaired, you can order a new control circuit board / smart board if that's economical, and since your sockets are bad, they will need to be replaced, too.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your
favorites.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you're changing the board yourself, you'll need to detach the keypad connector:
Some connectors will have a lock.
Dec 27, 2012 | Microwave Ovens
One of my microwave light under the microwave are blowing off with a big flash. The microwave still working after that, but the other light still on when I press the button to turning off. I decide to...
If your model is NN-P295SF, then the service manual is here.
Sometimes you get lucky and only a fuse blows, but either can cause a failure on the controller.
We often see this problem on the control panel, which we regularly repair by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jun 29, 2011 | Panasonic NN-P295SF Microwave Oven
Kenmore over range microwave oven / no power at all
Unfortunately, there is a good chance that when the bulb shorted out, it damaged the control board. The only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. The relays for the fan and the lights are part of the board. The power should always be disconnected when these bulbs are replaced or the board will be damaged. We would have an appliance repair person take a look to see what the deal is with the microwave.
Go here for Kenmore Microwave Parts: http://www.repairclinic.com/Kenmore-Microwave-Parts
www.RepairClinic.com
Feb 05, 2009 | Kenmore 62622 Microwave Oven
I HAVE A COUNTER TOP MICROWAVE MODEL #KOR611Q, AND EVERY TIME I PLUG IT IN IT BLOWS THE FUSE. I HAVE CHECKED ALL THE RECEPTICLES ON THIS CIRCUIT WITH A RECEPTICAL TESTER, EVERYTHING ON THIS CIRCUIT WORKS...
Remove the light bulb, if it still blows the fuse then it's not a bulb problem. More than likely the Magnetron has gone bad and is shorting. Be extremely carefull working inside any Microwave, it can be very dangerous! Sorry to say, but it sounds like it would be an expensive repair compared to a new (or used) oven.
Mar 06, 2008 | Microwave Ovens
GE SpaceMaker JVM XL1800
Sounds like the ERC board failed. It maybe covered under warranty, check that first cause a new ERC could cost around $150-$200. Anything electric can cause the .."what the*^&% just happened syndrome.
Dec 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Surface lights
I also have had a problem with the glass part of the surface light bulb separating from the metal base when trying to change the bulbs under my G.E. Spacemaker Microwave.. I see someone used a carrot or potato but I had not seen this suggestion before I whittled one end of a wine cork small enough to insert into the metal part of the old bulb stuck in the socket. It also worked great and in no time I was able to get the old base out and replace the bulb. I'll save the cork for next time because it seems to happen to at least one of the bulbs everytime they need to be changed. DON'T FORGET TO UNPLUG THE MICROWAVE FIRST!
Sep 05, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Under Hood Light, bulb is fine (brand new)
This is a problem with the control board, which we commonly repair for $32.50. This is caused by not disconnecting the microwave from the power line when removing or installing a bulb. Feel free to e-mail me at _ for more information or visit _ for full details.
Aug 20, 2006 | Whirlpool MH1150XM Convection/Microwave...
Daewoo KOC-925T Microwave Oven Logo
98 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
