Question about RCA HD52W59 HDTV Projection Television
Having problems with projection image on tv
Projection has triple images with concave effects. TV Model is 2005.
  • 3 more comments
  • bjcamp50 Aug 15, 2008
    tv has triple image problem color shados around everything, also picture has concave effects, tv sometimes shuts off on its own hd52w59 is 3 yrs old
  • w1ll1d Aug 17, 2008
    I have the same problem. When I fisrt turn it on I see a red nlue and yellow
    curved lines just before the picture comes on screen. The picure is fuzzy and words are shown in triple letters. Will dgaussing fix this problem?
  • jp76609 Aug 25, 2008
    triple exposure concave
  • lilianna_lo Aug 30, 2008
    tv has like a 3D image
  • meechiem00 Aug 31, 2008
    Ditto. My TV is 2 years old and just a couple of days ago I had the 3 colors at the top of the screen and everything is doubled or trippled!
    Genius:
  • 1,030 Answers
Ok let me get started by saying this is What is known as CONVERGENCE Your projection tv has 3 projection tubes Red Green and Blue. They all have to hit the same spot to create different colors they all have to come to a CONVergence as it were. Someone mentioned deguessing this only works with crt type tvs... Ok i see these set very frequently at the shop, I need to first ask you a few questions. FIrst one.. Can you go into customer setup menu. When you do can you see a option called "convergence" Very important if you do not see this option it might be a good thing. there is a common problem with these sets FL231 it is a very small special fuse that blowns due to poor connections.. IF you know how to solder and can get this fuse it will save you hundreds of dollars. Now if you do see this option then sorry the troubleshooting continues,,, next go into this option there should be 3 options autoconvergence red convergence and blue convergence first try auto convergence the screen should go black and start flashing little red blue and green boxes aroung the edge of screen. this takes a few minutes and hopefully it will end in a full green screen, if it ends in red then next try manual red and blue options u get a cross in center and when you up and down left and right it should move the red or blue cross with it.If it does move then it might need a service convergence. if it doesnt then you have trouble with ether what is known as convergence power supply or convergence amp board. and at this point i would suggest a tech. WARNING THIS SET GENERATES DANGEROUS VOLTAGES AND RETAINS THESE EVEN WITH THE SET UNPLUGED. I do not recomend inexperience person to remove the back cover of this set. BOy I did not realize i could get so long winded(lol) just be carefull and good luck and if you need any help just get back with me ill try to be reponsive
Posted on Aug 30, 2008
  • kete74 Jan 18, 2011
    I have this same problem with my RCA tv model # HD52W59. I do have the autoconvergence option but it doesn't work. Setting it manually doesnt work either. I have checked the fuse on the board and it is ok....have also looked to make sure there are no cracks in soldering. Any other ideas would be appreciated.
The picture has a triple image
Very common and easy fix. Install the RCA repair kit called ' ITC222 and ITC222A convergence option missing repair kit. Its available from www.tvrepairworld.com and contains the parts and the CD with repair instructions.
Jul 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The colors on my screen separate and triple the image I'm seeing.
The tv have an on going convergence problems.Just not total dead convergence effect yet.The tv convergence board require 2 STK convergence ICS,some or all it resistors to be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 06, 2010 | Philips 60PP9202 60" Rear Projection...
I have the same problem, but i didt myself
replaced the convergence ics if you have concave triple colored images on the screen.
Jul 17, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Triple image
You have convergence problems replace both of the STKs big black ics.
Dec 09, 2008 | Samsung HCL4715W 47" Rear Projection...
By the picture that you have supplied with the question you have a rear projection tv. The problem you are describing sounds like you have had the convergence module in your tv fail. Depending on the age and make of the tv, the repair costs ( if out of warranty ) can be prohibitive. The convergence module on rear projection tv's not only is in charge of bringing the 3 different color images together into a watchable picture but also handles the east west correction ( concave / convex aspect to the picture or lack there of ).
Jul 02, 2008 | RCA R52WH73 Projection Television
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
157 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
