Question about DK Design Group Touch Screen Music System with CD, Clock, Radio & Alarm
DK Design Group TS-1 Smart Touch CD system touch screen doesn't work
My Smart touch cd player won't work in the touch screen mode . I can us it with the remote ,but all the needed functions are not on the remote. Thanks, JD
Touch screen not working
The same thing happened to mine all you have to do is unplug you're car battery then plug it back up then it should work but first u have to calibrate before it works should calibrate very fast
Feb 15, 2013 | Soundstream VR-738NB 7-Inch Lcd...
Can't use touch screen on hp smart touch
If it is TouchSmart you have an issue with, go to the control panel and select touchscreen configuration. Make sure your global touchscreen settings are set to enabled. Click save and then close.
If this is not the issue it is possible there are hardware damages to the touch screen. Has it been dropped at all?
Jan 07, 2013 | HP Touchsmart Iq500 Driver Recovery Disc...
Jensen jiss-115 ipod touch doesn't work
It will cost you less just to get a different one (Shilia) then to have it repaired,
Nov 26, 2012 | Jensen JISS-115 PORTABLE DOCKING CD MUSIC...
Touch screen letters inop on right side. Also when I try to scroll on left side it selects a street instead.
try to calabrate the touch screen if it dosnt work replace the touch screen part# CSX1085
Jul 22, 2009 | Pioneer AVIC-D2 DVD Nav/6.5"...
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
hook your green/white camera override wire to your parking wire that should solve your problem
Feb 20, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Touch screen half loading only
Try uninstalling the TS from the control panel-system-devices (hardware).
Reboot and reinstall the drivers when asked.
The driver must match the OS.
The TS may be defective, does it operate proper on another Pc?
Mar 14, 2008 | Computers & Internet
Numark cdmix2 bpm counter
its for the count of a cd hit it on button sumware tap it in touch of speed temp o u wanna use beat match to anther cd bit count ok so tho both match up speed dual mode
Jan 23, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
69 people viewed this question
Top DK Design Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a DK Design Audio Player and Recorder Expert? Answer questions, earn points and help others
