Bose speaker only plays on left side of car when playing a cd. when i turn it back to the radio both sides play out equal again. what is the problem and how do i fix this?
the tests are easy, ask.
my guess is the weak side is bad, the load side is ok.
you can turn the volume down on the load side using volumn control
if yes that side is ok, fix weak side.
ask how, but make sure the wiring in all 4 corners are not damage
and at both ends of harness.
all speakers r connected to the same wires on the radio
If left/right balance and front/rear fader work properly
and sound is coming out it is likely (but not definite) radio is ok and speaker wiring is the issue.
HOWEVER, if it sounds the same on both left and right, it could be the radio. It is unlikely both sides have the same issue at the same time without it being in the radio.
The only way to verify it to disconnect the speaker and substitute a known good speaker.
So back to troubleshooting.
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Pink Car Radio Accessory Switched 12v+ Wire: Red/White Car Radio Ground Wire: Chassis or Strap Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: Orange Car Stereo Antenna Trigger Wire: Orange/Red Car Stereo Cell Phone Mute Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: Located under the rear deck in the trunk. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Dark Blue/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1992 Cadillac Eldorado Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange Car Radio Accessory Switched 12v+ Wire: Yellow Car Radio Ground Wire: Black Car Radio Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: Pink Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 5 1/4′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Tan Left Front Speaker Negative Wire (-): Gray Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Dark Green Car Audio Rear Speakers Size: 6′ x 9′ Car Audio Rear Speakers Location: Rear Deck Left Rear Speaker Positive Wire (+): Brown Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Dark Blue Right Rear Speaker Negative Wire (-): Light Blue
