Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Brushes not contacting floor
It seems to me that when my Hoover H3000 was new, the action of the brushes on the floor was audible, and I believe it also scrubbed better.
Now, however, I don't think the brushes are contacting the floor much any more. Probably worn down a bit.
I don't want to spend $35 for new brushes, unless I absolutely have to. My H3000 also needs a new nozzle because somehow the squeegee isn't flat anymore, so vacuum action is deteriorated. That costs $55. $90 is an awful lot for just parts. I'd be tempted to get the newer model for $70 more, rather than keep my old one at that rate.
So. Is there a way to somehow get the brush assembly to lower during use, as a workaround? Alternatively, is there another source for H3000 parts? If there is either one, I would very much appreciate hearing about it.
Thanks in advance.
  • 24 Answers
It is unlikely that you have worn the brushes to the point that they no longer contact the floor properly unless you use it daily and have a very rough tile or concrete floor and even then they should outlast the machine. It is more likely that there is a problem with the switch that moves them up and down for different floor settings. Also remember that the brushes will be up while the unit is in the upright position no matter what the switch is set to only when you bring the handle down in the operating position do the brushes lower to contact the floor. Pull the brushes out and check to see nothing is interfering with the operation of the brush adjustment or for any broken parts. As for the squeegee they do get deformed and this will prevent the unit for sucking up the water properly so it should be replaced if needed. For any parts visit www.stevessewandvac.com if you don't see what you need listed email them someone can help.
Posted on Aug 13, 2008
Hoover 8+spin1600 forever banging when spinning16
Hi! If your unit is noisy while the brushes are spinning this can mean that your brushes are worn or damaged. Try removing the brushes by pushing the two brush release buttons at the same time. Turn the cleaner on and see if the noise persists. If the noise stops with the brushes removed, you will need to replace your brushes. I have included a link below where you may go to purchase a replacement brush roll if needed. Hope this helps!
Search Results
Oct 02, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
H3000 Motor becomes very hot during use
Over heating on a floormate is cuased by obstructions or a clogged up filter. Try running it without the recovery tank. If it doesn't over heat you need to check for obstructions in the nozzle and the tube leading up to the recovery tank. if that is all clear, a new filter should fix it.
If the machine over heats without the recovery tank on it, you might be right. Hoover only sells motor assemblies, not just the brushes. I have never seen them used enough to need new motor brushes simply because of wear. If the brushes are worn down completely, there is probably a short in the motor.
Let me know if this helps.
Dec 31, 2012 | Hoover Floormate H3000 Upright Wet/Dry...
My Hoover floormate motor started smoking. It is over 9 years old. I keep the floor brushes clean. I am wonder if replacing the mother is worth it.
MSRP on this motor is $69.95. Labor may be another $30.00. I often see these units in thrift shops, which may be worth a try.
Jan 29, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Loud noise, smell smoke, brushes turn slower than before, stoped using
yes there are replacement parts for your hoover call any athourized hoover dealer and give them your model # usualy the motors are more expensive than the hole machine
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I used my Hoover FloorMate, SpinScrub Hard Floor Cleaner for the first time today. My intent was to clean the grout in my kitchen/family room floor. Since the water was dirty I know it cleaned the grout...
The Hoover model 800 has seperate brush assembly to do grout. The 500 model (yours) has only the one hight brushes so other means must be taken to do grout. I have a 500 and all tile floors and I'm bumbed too.
Kirk Thompson
San Juan,PR
Aug 14, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I have a H3000 Floor Mat The problem is it want pick up the water after the scrub clean the floor. What could be the causeing the problem?
Hoover H3000 Floor Mat
I have a H3000 Floor Mat the problem is it won’t pick up the water after the scrub clean the floor. What could be the causing the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The problem could be that the Hoover H3000 Floor Mat could be clogged or something is blocking the suction port or you may have a pinched line of some type of which would cause it to not pickup, feel free to check with a local vacuum dealer in your area or in the yellow pages or the Hoover factory phone number is listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floor mate wet/dry - brushes do not spin
Hey there bankshots, if you look at the bottom of the head of the vacuum, you should be able to see the brushes. Their are some screws to remove to gain access to the inside of the bottom panel. When opened, you should be able to see the entire spinning brush assembly. On one side, there is an area which has no brushes and may contain the remnents of your belt which most likely is the problem. These belts are often replaced and not the sign of any thing to worry about. Replacements can be found at registered repair facilities. Alternately, a professional will do it for you for a modest charge. Also your warranty may cover this if your machine is less than a year old, or you purchased the extra protection from the seller. Good Luck!
Jan 28, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
49 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
