Question about ASUS P4PE-X Motherboard
Asus P4PE-X Board dead. Looking for a replacement. Must have 845PE chip set. Must also have the same physical back plane layout. Any suggestions? bkrogstad@earthlink.net
  • 594 Answers
Here is the link to ASUS. contact them and let them know what you are needing.
http://support.asus.com/default.aspx?SLanguage=en-us
Posted on Aug 14, 2008
My sound card missing, asus p4pe-x 845GE
You can download the audio and device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jul 27, 2011 | ASUS P4PE-X MB 845PE/ Audio/ LAN...
Vga & sound card
try new cards if that dose not work than the board mybe bad look at boards caps to see if they have a round head on top if they do board bad jim
Apr 17, 2011 | ASUS P4PE-X MB 845PE/ Audio/ LAN...
How to download motherboard driver
http://www.driverstock.com/ASUS-P4PE-driver-download/6-9-10029/index.html
try this ;) or go to asus.com
I found the user manual: http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4pe/e1110_p4pe.pdf
Mar 02, 2011 | ASUS P4PE-L 845PE Motherboard
I have asus p4pe x/se and installed a 32bit windows 7 ultimate ./ i need ethernet drivers plz some help ?
Asus doesn't list any windows 7 Drivers for this board and
Broadcom says of the windows 7 Driver for this series:
This driver does not support BCM5700, BCM5701 and BCM5702 devices. To use these devices under Vista, Windows Server 2008, Windows Server 2008 R2, or Windows 7, please use the XP or Win2K3 driver above.
So here is the link to grab the Windows XP/2K3 drivers: Good luck!
http://www.broadcom.com/support/ethernet_nic/netxtreme_desktop.php
Jan 10, 2010 | ASUS P4PE-X MB 845PE/ Audio/ LAN...
No audio
Have a look at the tips in this windows xp sound troubleshooting article. Maybe that helps.
May 10, 2009 | ASUS P4PE-X MB 845PE/ Audio/ LAN...
Bios for Motrherboard P4PE-X
Hi Reinaldo,
I assume your mobo is an ASUS, based on 845PE intel chipset, just follow the link below:
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P4PE-X
It requires for you to select your OS to download.
Good luck and have a nice day.
regor
Oct 13, 2008 | Computers & Internet
P4PE-X Motherboard bus speed
JAAh,
I have the same motherboard and did a little reading. The chipset on these motherboards was not really designed for the 800MHz, but it was still used by ASUS anyways. I have reduced the FSB speed on my system for increased stability. Here is the posting from another site which I found.
The 845PE Northbridge was designed for FSB400/FSB533 processors,using DDR266/DDR333 memory. (See page 11 in the Intel spec.)
http://developer.intel.com/design/ch...s/25192401.pdf
No matter how many different models of this motherboard that
Asus made, it is still based on the 845PE. Operation at FSB800
with DDR400 memory constitutes overclocking, and overclocking
comes with no guarantees (only Intel can test the chips and
bin them for speed, and the chips are not tested at FSB800/DDR400, so Asus has no way of knowing how far they can be pushed).
I've read descriptions of other people's luck with the 845PE
and it is described as "I can set the clock to 200MHz and
not a stitch more". That means even in the best case, there is
absolutely no margin left. The fact that your board runs stable
at 190MHz, instead of 200MHz, should not be a surprise, as Intel only has to guarantee the chips work at 133MHz (for FSB533).
The sin being committed here, is the user manual should state
that "overclocking comes with no guarantees". Persons interested in buying FSB800 processors, should be buying a P4P800/P4C800 or equivalent board, as the Northbridge chips on boards like that are guaranteed by Intel to run at FSB800.
If you want rock solid operation, pair a 3.06/FSB533/512K
Northwood processor with the 845PE Northbridge.
http://www.asus.com/products/mb/fsb800.htm
HTH,
Paul
Dec 24, 2007 | ASUS P4PE-X Motherboard
ASUS P4PE-X Motherboard Logo
196 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
