Question about HP OfficeJet 6210 All-In-One InkJet Printer
Error message 421*
I can not fax, I am recieving error message 421*. The paper goes thru but it isn't being faxed. How do I fix this?
Else
  • 40 Answers
Error 421:
A handshaking error has occurred at some point in the process from the fax that originated the fax.
* Try the fax at a different time when telephone line conditions have improved.
In some cases this error can occur if the other fax machine is using a fax format incompatible with the HP fax.
- you can try to set the FAX SPEED to SLOW
- ERROR CORRECTION MODE to OFF
you can locate this on ADVANCE FAX SET-UP...
Posted on Aug 31, 2008
Sf5100 says recieve error
take the power out and hold the red button in. put the power back
Jul 21, 2011 | Samsung SF-5100 Plain Paper Laser Fax
We are not receiving faxes..we keep getting error code 407..Please help? Thank you.
The message means:
407 No confirmation from the receiving station for the
previous page sent.
Wait a few minutes and send again.
This can mean 2 things
1) you have not set your fax machine to recieve faxes
2) you need to have your fax machine serviced because the part that makes it pickup a fax has malfuctioned
Clean all paper paths with paper path cleaner.
Unplug and then after 10 seconds replug the fax machine and do a test recieve for it
If all else fails, you may need to call a service person to repair or replace the broken or defective part that recieves faxes.
Hope this helps :)
Mar 16, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
Problems sending. the paper starts to go thru then stops and prints out an error message
Try turning the machine off and on again.. it sounds like a memory problem..
If that fails give the fax a good blow in where the paper goes in.
Oct 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Fax-1030 plain paper sending constant 'check paper' error
I got this error when I put the paper in without pulling forward the flap that hold the paper. It seems that the action of returning the flap to it's closed position sets the paper in the correct way.
I'd give that a try.
Mar 16, 2009 | Brother FAX-1030e Plain Paper Thermal...
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Paper mismatch when recieving a fax
I understand that while receving faxes, you are experiencing with paper mismatch error message.
Please select the paper type as plain paper fromt the front panel of the All-in-One and try to recevie faxes.
Mar 27, 2008 | HP Photosmart 2710 All-In-One InkJet...
Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Feb 08, 2008 | HP Officejet 9110 All-In-One InkJet...
ERROR 1200
The error 1200 refers to a problem with one or both of your cartridges, and as the printer uses these cartridges to print, it will not be able to print any recieved faxes. To avoid lost data, it blocks all fax usage as a result of recieving this message.
Nov 14, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Can't recieve a fax
i have fax L100 ,i can send a fax but i cant recevie a fax error is communication error (003F)
Oct 24, 2007 | Canon FAX L-120 Plain Paper Laser
Canon 2060 fax
there is a jam sensor stuck or a small piece of paper caught, did you look in the back door.
Sep 11, 2007 | Canon LaserClass 2060 Fax
HP OfficeJet 6210 All-In-One InkJet Printer Logo
963 people viewed this question
Seeker5211
Seeker5211
