Question about Logitech Inc MX610 Laser Cordless Mouse DH931350
Wandering cursor When I am typing an email or any word document, I can be typing, say, on the third line and then my cursor shifts to the first line and, if I don't notice, the typing carries on along the first line. This so frustrating. Any ideas please, Barbara Barker
  • senorababs Aug 17, 2008
    Hi, I thought the problem was with the mouse at first, so I contacted the manufacturers and they sent me a new one and it was no better, so it rules out this suggestion, but thanks for trying
    Barbara.
  • 3,037 Answers
The mouse is wearing out. The left click button to be exact.The spring isn't keeping it up and so it is accidentally making a connection and clicking and wherever the cursor is, the typing moves to. The easiest thing to do, is just invest in a new mouse. Mechanical things will wear out over time. I'm sure you have had it for a while and use it alot. If it is still under warranty (most likely not), then just return it for a new one. Let me know if you have any more questions
Posted on Aug 13, 2008
  • Logitech Master
  • 13,433 Answers
Are you using a laptop? if you are using a laptop you may be touching the touchpad, I woulld recommend either use a external keyboard or then you need to press the button FN and one of the f1-f12 keys debending on your laptop to turn off the touchpad.
  • Ekse Aug 13, 2008
    Also try cleaning your desk and the bottom of the mouse, there may be some dirt in the bottom which makes the sensor think the mouse is moveing.
  • Ekse Aug 17, 2008
    are you able to see my solution?
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
What says home or end keys
it is primarily used to return the cursor to the beginning of the line where the cursor is located. When the text is not editable, the home key is used to return to the beginning of the document; this can also be done in editable text if the key is pressed along with control.
The home key can also be used to highlight all the characters before the cursor in a certain line if pressed along with shift in editable text.
The home key will take you to the beginning of the line you are on - try it, type a bunch of stuff then hit the Home key and you will be brought to the beginning of the line. If you are in a multi-line document, hitting CTRL+Home will bring you to the start of the entire document.
Similarly, the end key will take you to the end of the line while CTRL+end will take you to the end of the document
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 18, 2010 | HP 381068-001 Pavilion ze2000 Keyboard
I want short cuts in ms word
You can use this
Ctrl + A Select all contents of the page. Ctrl + B Bold highlighted selection. Ctrl + C Copy selected text. Ctrl + E Aligns the line or selected text to the center of the screen. Ctrl + F Open find box. Ctrl + I Italic highlighted selection. Ctrl + J Aligns the selected text or line to justify the screen. Ctrl + K Insert link. Ctrl + L Aligns the line or selected text to the left of the screen.
Ctrl + M Indent the paragraph. Ctrl + P Open the print window. Ctrl + R Aligns the line or selected text to the right of the screen. Ctrl + T Create a hanging indent. Ctrl + U Underline highlighted selection. Ctrl + V Paste. Ctrl + X Cut selected text. Ctrl + Y Redo the last action performed. Ctrl + Z Undo last action. Ctrl + Shift + F Change the font. Ctrl + Shift + > Increase selected font +1pts up to 12pt and then increases font +2pts. Ctrl + ] Increase selected font +1pts. Ctrl + Shift + < Decrease selected font -1pts if 12pt or lower, if above 12 decreases font by +2pt. Ctrl + [ Decrease selected font -1pts. Ctrl + Shift + * View or hide non printing characters. Ctrl + Moves one word to the left. Ctrl + Moves one word to the right. Ctrl + Moves to the beginning of the line or paragraph. Ctrl + Moves to the end of the paragraph. Ctrl + Del Deletes word to right of cursor. Ctrl + Backspace Deletes word to left of cursor. Ctrl + End Moves the cursor to the end of the document. Ctrl + Home Moves the cursor to the beginning of the document. Ctrl + Spacebar Reset highlighted text to the default font. Ctrl + 1 Single-space lines. Ctrl + 2 Double-space lines. Ctrl + 5 1.5-line spacing. Ctrl + Alt + 1 Changes text to heading 1. Ctrl + Alt + 2 Changes text to heading 2. Ctrl + Alt + 3 Changes text to heading 3. Ctrl + F1 Open the Task Pane. F1 Open Help. Alt + Ctrl + F2 Open new document. Ctrl + F2 Display the print preview. Shift + F3 Change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word. Shift + Insert Paste. F4 Repeat the last action performed (Word 2000+) F5 Open the find, replace, and go to window in Microsoft Word. Ctrl + Shift + F6 Opens to another open Microsoft Word document. F7 Spell and grammar check selected text and/or document. Shift + F7 Runs a Thesaurus check on the word highlighted. F12 Save as. Shift + F12 Save. Ctrl + Shift + F12 Prints the document. Alt + Shift + D Insert the current date. Alt + Shift + T Insert the current time.
Oct 11, 2010 | G7 Productivity Systems VersaCheck For MS...
Cursor jumps around when trying to type documents and emails. Sometimes emails actually send before you are finished typing.
remove hard drive and take it to your nearest computer technician to scan your drive for maliciuos and viruses...
Oct 04, 2009 | Computers & Internet
Mouse keeps shifting the cursor to a different place in document
On touchpads if you touch the pad twice in quick succession it acts as a click and the cursor will move to the mouse pointer location. In mouse settings disable "tapping"
Aug 31, 2009 | Acer Aspire 5720 Notebook
Acer Aspire 7720 Notebook Keyboard Problem
Yes there is a fix for this issue. Try the following
1. Open control panel
2. Click on "MOUSE"
3. Click on "POINTER OPTIONS"
4. Uncheck "HIDE POINTER WHILE TYPING"
5. Click Apply
5. Click "OK"
Mar 16, 2009 | Acer Aspire 7720 Notebook
Depressing spacebar causes cursor to jump down a line.
i had that problem once
right under the space bar on some dells
there is a ribbon cable that plugs the mousepad into the motherboard
its just a small clip must be checked
Mar 14, 2009 | Dell Vostro 1500 Notebook
Cursor jumps erratically
Most likely, your wrist is gently touching the touchpad, and your computer is interpreting it as a 'tap,' and it so happens your cursor was located several lines up.
Or if you use a separate mouse, is it on a wood or uneven surface? This will cause it to jump up those few lines and again, your wrist (or if you have big hands like I do, the bottom of your thumbs) will tap it.
Apr 02, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
187 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
