Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Where are the screws
I can locate the screws you mentioned. Where are they?
Take off light cover
Posted on Sep 21, 2008
How do i remove the cover to check the fanbelt on my Miele s7260. The brush has stopped spinning and when i tried to check i found that it had unusual screws. They are not the flathead or phillips type but...
Did you check the belts that go around the end of the brushes?
There is a service panel that remove with a coin. It is located at the rear, bottom of the vacuum.
The star shaped screws you mentioned are Torx screws. You can get a set of torx drivers at any hardware or home improvement store.
Hope this helps, if it does, please place a vote for me.
Good luck,
Handie Andie
Mar 27, 2011 | Miele S7210 Bagged Upright Vacuum
No directions to change my belt in manual!
generally there is a bracket that holds the brush in place on the roller side of the vacuum. there should be four noticeable screws to remove. the bracket will detach and reveal the belt, brushroller, and suction shroud
Jan 01, 2010 | Vacuums
How to clean turbo brush of harmony electrolux and put it back together properly
Wait, there are two more screws that must be removed before the top shell will come off. They are located under the wheels. Pop the wheels out by simply inserting yoru finger or a small tool into the wheel and pulling straight up. Remove those two screws and then you can proceed as mentioned above.
When reassembling the head, if the shell does not snap back onto the base, check for plastic chips or other debris in the narrow slots on the underside of the shell. Clear these slots out and the head should easily snap back together.
Dec 02, 2009 | Electrolux Harmony Canister Vacuum -...
Where is the belt located, and how do i get to it
THE BELT IS LOCATED UNDER THE BRUSH COVER TURN VACUME UPSIDE DOWN AND THERE SHOULD BE SOME SCREWS THAT HOLD THE COVER ON REMOVE THE SCREWS AND YOU CAN REMOVE THE COVER WHERE THE BELT IS LOCATED
Sep 16, 2009 | Dirt Devil Vacuums
I would like to see how to change the belts on the bissell 8910 pro heat I have looked for hours now. I saw the book but it mentions and shows nothing on how to replace them. Help please.
turn the vacuum over so that the bottom side is facing you, remove the 4 screws on each side using a Philips screw drive set the screws and the brush cover aside.
- pull brush straight out and you will see the gray rubber band.
-replace the new drive belt over the motor pulley and the floor brush.
-replace the floor brush by lining up with the slots and rotate untill centered , install the cover and screws . done your back in action.
Hope this helps.
Sep 05, 2009 | Bissell 8910 ProHeat Clear View Upright...
How to dismantle to replace brush drive belt
Check for cross head screws on top of the hood. Usually located either near the pedal release and then on the other side. Either that or flip the machine over and you should be able to locate screws on the underside that will remove the sole plate. Once that's done dont lose the screws - if either top or bottom is removed you should be able to access the drive belt.
Apr 01, 2009 | Sunpentown V-8506 Bagless Upright Vacuum
Brush Bars won't turn
I borrowed a bissell 9500. It was filthy with the previous user's debris, including long and short black hairs, black goo from the swamps of hell, cat hair and dirt. I cleaned the whole machine (as mentioned in the online user's manual), pre-spotted my carpets, filled the appropriate fluid containers, and confidently turned power on to the 9500. The BRUSHES DIDN'T WORK ! After checking all belts, and other things mentioned in other solutions here on Fixya, I decided to check the trigger setup on the handle part of the cleaner. I unscrewed all the screws from the top of the handle down to the attachment holder ( there were seven screws). After that, I gently pried open the top portion of the handle in order to see down to the trigger. I gently pulled the trigger and, at the same time, repositioned it and the spring attached to it. Then, I put the screws back in, attached the power cord, turned on the power, released the handle's upright lock. When I did that, the brushes turned like they are supposed to. At that point, I felt like I'd awoken from a nightmare and, at the same time, been blessed by an unseen cosmic power. The rest is history. My carpets and upholstery are now as clean as when they were new. I hope this helps one or more of you out there with the "dead brushes" problem.
A solution submitted by:
Pierre Kunde
peter.kunde@gmail.com
Sep 15, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need to remove bottom cover of Panasonic MCV7314 vacuum to see if the belt is broken. I can't figure out how to remove and can't find a manual online.
I did a search for the manual for that model and found a pdf file online that had instructions and pictures. It was still slightly different and hard to get off. I took out two screws and then held in two side "clips" and wrestled it off. I dont think the manual mentioned removing the screws,but instead mentioned two laches that I never found. Here is the link. Instructions are on page 30.
http://service.us.panasonic.com/OPERMANPDF/MCV7314.PDF
Is there a charge for your assistance? I was not sure and that is why I didn't continue.
Jul 15, 2008 | Panasonic Vacuums
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
