Question about Brother MFC-7820N Printer
Mfc 7820n prints weird black line down side of page
Our printer has begun printing a weird stripe down the right edge of all papers during all functions. It almost looks like tabs from a file folder, but then also has a little point in it also. I think it must be printing some component inside the printer. Is there a way to calibrate it or somethin?
  • Sptwn Oct 16, 2008
    Black line down middle of page when copy or fax is done through the
    top feed. Flat bed is fine.
  • lfuller2023 Dec 09, 2008
    I get a black line down the side of the printer, not the center.
  • 3 Answers
Error 009
Posted on Aug 27, 2008
Brother says "Dust on Drum" wont print, and when does the page has two black lines down the middle
Yes some of dust have your printer drum unite.Open drum and clean it then solve your problem.
Nov 12, 2009 | Brother MFC-7820N Printer
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
Vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Jun 01, 2009 | Brother MFC-7820N All-In-One Laser Printer
Brother MFC 7820N Smudging Concern
If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobellaâ„¢ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Brother printer that prints a black line down center
probably a bad drum cleaning blade, It's part of the drum unit
Feb 02, 2009 | Brother MFC-7820N Printer
Old canon copier prints thick balck line down right side of paper
tthis is really old 25 years plus. replaced the drun cartridge which also contains the toner good luck canon sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Dec 13, 2008 | Brother MFC-7820N Printer
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
The 7820N prints double-sided manually using the drivers. From Windows, select File / Print. On the pop-up window, click on Preferences, select the Advanced tab, click on the A/B pages icon, and select Manual Duplex. "OK" your way out. When you print, you'll first confirm to print one side of all pages. Then follow the instructions that appear.
Jan 25, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Printer Logo
686 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
