Question about InFocus LP 580 Multimedia Projector
Lost video cable Part # 210-0014-05
Does anyone know where I can get another cable for this projector?
  • calbright Aug 13, 2008
    I have checked all of the websites that say they have the cable. It is not available thru them or Infocus. The cable will have to come from someone that has surplus equipment.
  • 10,594 Answers
Please click HERE to get the cable. Hope this info will help you.
Posted on Aug 13, 2008
  • Shahid Electronics
    Shahid Electronics Aug 13, 2008
    I hope there would be another cable as replacement or subsitute like that.
I have a pioneer VSX-822k receiver. My older Runco CL-710 projector with DVI will not display anything from the Pioneer's HDMI output. (using a monoprice HDMI to DVI cable designed for this) The sourc
it is not compatable with 1080p,it says so on pg 17 of the projector manual,This unit is compatible with the following computer resoultions: 1280x720, 1024x768, 800x600, 640x480,you cannot use it with the receiver unless you use rca cables http://www.projectorcentral.com/pdf/projector_manual_2126.pdf
VSX 822 5 1 Channel 3D Ready Receiver
Oct 18, 2014 | Audio Players & Recorders
PDG-DSU30 black and white video
check your HDMI/VGA cable this is sometimes cause the color lost. change it or try another cable...
Dec 05, 2013 | Sanyo PDGDSU30 Video Projector
Intermitant loss of picture
The problem looks like a mainboard problem if you have checked all the cable connections going from your source to the projector.If you are yet to confirm the cables, then u should try to check the connections by putting a spare VGA / video cable
Jan 18, 2013 | Epson PowerLite Home Cinema 3020 LCD...
How do I connect my Benq-mp610 projector (without HDMI) to my ps3
hi,
u can convert the vga input of ur projector to component video input, and u can connect ur ps3's component video to the projector. component video to vga convection cables are available.
ok
Dec 27, 2010 | BenQ MP610 Multimedia Projector
S-video connection from freeview box - only black and white image
It's quite rare for Freeview boxes to have S-video output (even through the SCART). I suggest checking that your box does in fact provide S-video out.
Nov 07, 2009 | Acer Office Equipment & Supplies
Audio doesnt come thru my hdmi cable from the dvd player. And video doesnt go thru hdmi cable to projector. Have to run rca cables to both
Hi there
Check your DVD players' settings/manual to ensure the HDMI port is the default output port. Also confirm that both audio and video are enabled on that HDMI channel as it can be separated to be only video or only audio in a lot of cases.
Confirm you are at least getting video out from the DVD with a direct connection to your projector with the HDMI cable.
If video is making it to the projector direct from the DVD, you will need to confirm your amp is monitoring the HDMI input if there isn't a specific input selection for it. Connect your DVD to the amp and your amp to the projector and test again that you are still getting video AT LEAST. This will help narrow down which device is not playing the HDMI game if you still have issues at this point.
To sum up;
Confirm HDMI is the default output from the DVD for both audio and video.
Ensure you are getting video AT LEAST with a direct test to projector.
Confirm your amp is monitoring the HDMI input coming from the DVD.
Hope this helps.
Jul 29, 2009 | Yamaha HTR-6130 Receiver
How do i connect cable tv to my dell 2200mp projector
You can connect it directly with a composite cable. There would be a RCA(yellow) video output on the back of your cable TV. This is then connected to Video input(yellow) f you projector.
If your cable TV has Component output (threr RCA cable Green, Red, Blue), then these thre RCA could be connected to the similar one available on your Projector.
You could connect your sound als o thru the RCA out of Cable TV and input of Projector. But if you have a good AV Receiver or a sound system then it best suited for it, since the projector speaker is mono and only 2Watt output.
Let me know if there are any specific inputs required
The Dell 2200 mp projector has the following compatibility
:HDTV: 1080i, 720p
EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes
Mar 03, 2009 | Dell 2200MP Multimedia Projector
Can't use my hp sb21 with my Macbook
it works if you do it in bootcamp. but have to select external monitor instead of digital display under the intel graphics control panel. does anyone know of such an option under OSX?
Jun 13, 2008 | HP Digital Projector sb21 Multimedia...
Questions about Onkyo SR505
1, remote codes, check with sayno for code updates. Or consider a harmony remove last remote you will every buy.
2. Receiver does not convert video standards, need svideo cable.
3. popcorn hour player, no idea what that is , but like number 2. will need a seperate hdmi cable.
However, if the receiver and the player both have component, i would not hesitate to wore everything up component. In your application component video is better than hdmi. To many reasons to list. Good luck
Jun 10, 2008 | Onkyo TX-SR505 Receiver
Canon projector model LV7250
You can download the manual here. Instructions for cleaning/changing the filter are in the Appendix, page 51.
May 12, 2008 | Canon LV 7300 Multimedia Projector
InFocus LP 580 Multimedia Projector Logo
252 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
