Question about Enterasys Distributed Forwarding Engine w/12 1000BASE-X Ports (mini-GBIC) ( 7G4270-12 ) (7G427012) Transceiver
PORT FORWARDING TRING TO GET NAT FROM MODERATE TO OPEN OR SEVERE
How do i port forward a port number off bittorrent
Posted on Aug 15, 2009
Every time i try to join my friends game it says session is ureachable and it is really annoying. We live at different IP addresses and could connect before. We all have the same DLCs and it is only me...
make sure you and your friends have open NAT, you need to port forward certain ports for xbox live on your router, try to check if ubisoft also has specific ports need to be open. if still the same contact your ISP, they might be having problems.
Mar 23, 2011 | Ubi Soft Assassins Creed: Brotherhood for...
How do i open my NAT type? i have moderate NAT type and i wish to open it, how to do so?
login to the router and enable uPnP - it should be on the security screen. if you don't have uPnP as an option you will need to use port forwarding rules. These depend on the application reporting the moderate NAT.
Let me know if you need further details on how to get into the router.
Dec 18, 2010 | Arris SURFboard SBG900 Wireless Router...
Hello. I need to change my NAT type on my Xbox 360 from moderate to open using a Westell Versalink 7500 router.
Hello
Your router does not have moderate or open nat options.
Options that it does have are Public Lan - nat type and Private Lan -nat type.
Your router also has a DMZ feature and port forwarding options.
User manual for your router is available at http://www22.verizon.com/ResidentialHelp/HighSpeed/Networking/User+Guides/User+Guides.htm
To get your xbox live working properly, you can try using the public nat type, if that does not solve the problem, turn on DMZ for the address of the Xbox360. Now if that still does not solve the problem, then you would need to set up port forwarding for all the ports that xbox live uses.
I would personally recommend that you enable port forwarding for the required ports.
Ports that need to be open are
TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Together with the user manual and xbox360 portforwarding guides that are available here http://portforward.com/english/applications/port_forwarding/Xbox_Live_360/Xbox_Live_360index.htm
You will be able to get it working.
But since that is a lot of information for anyone that has not used port forwarding before I'll write down step by step how to get started.
First get on your computer, You need to connect to the routers own configuration page. By default this is http://192.168.1.1
So, open your internet browser and write HTTP://192.168.1.1 and press enter.
Now you get a a user and password prompt. the username is admin and the password is password. all lower case.
Now on the top menu, click on Firewall settings.
Now select Port forwarding. more information and pictures on the user manual page 98 and forward. You need to create a new rule or rules that forward the above ports - allow them to be open to the internet for the xbox 360.
Looking at page 112. You would create a new port forwarding service, you need to add all the ports one by one. And the host device would be the IP address of the xbox.
Now the DMZ option will be simpler, that is on page 118. You just need to find the xbox ip address from its network options and put it there, and turn on the DMZ. That will allow all traffic for that machine.
Let me know how far you get. I'll help if you get stuck, sorry if this post is a bit unclear, this is a very small box to write in, I can't easily see everything I've already written here.
Sep 27, 2010 | Computers & Internet
NAT from moderate to open (xbox 360)
You need to open ports for that game on your router. Nat can't be disabled, make sure the correct ports are properly forwarded on your router. Contact the game manufacturer for the port listing.
Aug 21, 2008 | Computers & Internet
Port forwarding
do one thing you go the inside router then select port forwarding and give the x box ip address you get it
Aug 12, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
How do i change my NAT setting from strict to open
The NAT usually has to do with a device connected to a router. You cannot change the NAT on a modem, only a router. To change it to open, you have to simple forward ports.
May 09, 2008 | Computers & Internet
Nat type
Try this link this shows how to forward ports on your belkin router.
Apr 13, 2008 | Belkin N1 Vision Wireless-N Wireless...
How do i get NAT OPEN
To get the NAT open, you have to forward specific ports. If you are doing this for xbox live, then call microsoft and ask for an "agent." Tell them that when you test your xbox live connection, your NAT is strict or moderate. They will give you a specific port to open. With that information, You go to your router's setup, and look for port fange forwarding. Enter the information given and save it. For further assistance, call netgear's help line and they will help you.
Mar 31, 2008 | NetGear WGR614 Wireless Router
Xbox live connection: My NAT
its likely your router needs to have port forwarding setup on it, or you could try setting up your Xbox ip address as a DMZ on your router.
however some routers simply wont work, I had a voyager 105 using port forwarding but it still never worked till i changed to a Draytek
post more details of your router and what you have tried.
also you cant go far wrong visiting here
http://www.xboxlivetheguide.co.uk/XBoxLiveTheGuide2.php?department=Home
Mar 10, 2008 | Microsoft Xbox 360 Console
Enterasys Distributed Forwarding Engine w/12 1000BASE-X Ports (mini-GBIC) ( 7G4270-12 ) (7G427012) Transceiver Logo
242 people viewed this question
Top Enterasys Computers & Internet Experts
George Nalley
Level 1 Expert
Marcin
Jax Planet
Jax Planet
Are you an Enterasys Computer and Internet Expert? Answer questions, earn points and help others
