Data Recovery I have deleted accendently my extended partitions of hard disk,but not yet formatted. These partitions Are having my very important data.Please help me out to recover my data from these partitions.
  • 796 Answers
Actually it is not able to delete the partitions when you are logged into windows....
try to disconnect the harddisk from the system(remove both the data and power cables) and then reconnect them again..
even if it doesnt work try the software called as PARTITION MAGIC
thankyou,.
regards
JC
Posted on Aug 13, 2008
Tip
Hard Disk Data Recovery
Definition of Hard Disk: Hard Drive is a storage device where you can store any types of data and file. Hard Drive is available as external and internal device. We know PC storage device as internal system Hard Disk. When you save data or install programs on your computer, the information is typically written to your Hard Disk. The Hard Disk is a spindle of magnetic disks, called platters, that record and store information. There are several interface standards for passing data between a Hard Disk and a computer. The most common are IDE and SCSI. Hard Disk is made of one or more aluminium or glass platters, coated with a ferromagnetic material. Most Hard Disks are found as Parallel ATA (PATA), Serial ATA (SATA) or SCSI device.
Difference with Floppy Drive:
The term hard is used to distinguish it from a soft, or floppy, disk. Hard Disks hold more data and also faster than floppy disks. As an example a Hard Disk can store anywhere from 10 to more than 100 gigabytes, where most floppies have a maximum storage capacity of 1.4 megabytes. Floppy is more risky device than Hard Disk for losing data.
Problem with Hard Disk:
Most common problems of Hard Disk which may arise anytime are Booting problem, OS Installation problem, Hard drive crashing and another Hard Disk not showing original space or not showing partition etc. But in every case the risk is loss of data. In some of cases formatting and reloading of Operating System can recover your Hard drive and make it useful but formatting can recover a blank Hard Disk only without data. But you have to recover Hard Disk with data, so formatting is not possible.
Data Recovery:
Data recovery is the process of retrieving back data from the damaged media. The damage of storage media can be physical damage and logical damage. The data is retrieved back by recovery experts after determining the type of the damage caused to the storage media. Most of cases data recovery is important and formatting is not possible there. So that I need to choose another way for solution of this type of problems of Hard Disk. The first and secure way to recover a Hard Disk is using data recovery software.
Recover Data from crashed Hard Disk: Power surges, Software Corruption or Malfunction, Hardware or system failure, Natural calamities, User errors may crash your Hard Drive. Data recovery software helps to retrieve or recover the data from the crashed hard Drive. Data recovery software gives an easy and Graphical User Interface with less difficulty so that the data can be recovered easily. The recovery software helps to recover the data and restore them on a second Hard Disk, the Hard Disk being connected to the computer and recognized by the BIOS, the recovered data can be stored on a safe location on the second disk.
Logical data recovery: In a data loss situation when the Hard Drive is perfectly fine and the BIOS recognizes the Hard Drive but reports a read error, logical data recovery technique is very helpful. Here the files that are damaged or corrupted by any user error or virus attack are rebuilt rather than repairing the Hard Drive.
Fragmentation: When the FAT entry is lost during accidental file deletion, formatting or partition deletion that particular block of Hard Drive becomes inaccessible. Some data recovery software makes an attempt to rebuild the files without a FAT entry. This technique is very efficient if the file size is smaller than the clusters size. But it is inefficient in recovery the larger files.
Data Recovery from deleted partition: Partition is allocation of memory in different sections. Each partition will be like separate disk drives. Partition is very use full when the user is using operating systems more than one. Usually after formatting the disk it may not be able to recognize a partition because of accidental deletion of the partition table or by virus infection. The partition is not actually deleted; it can be recovered by using recovery tools and copy the data present in the partition to the required destination. Formatting the drive erases a large amount of data present on it, but not all the data. The recovery of the data depends on the fragmentation of the file system as the parts of files are being placed on different places in the drive. The data recovery software will assume that files were not fragmented and stored in continuous clusters. If the partition was formatted using different file system, then recovery process will be very complicated.
Another Data recovery process: If you don't have any data recovery software you can try another process to recover data. Attach the Hard Drive with another system in slave or second SATA.If detect the drive then boot to the first Hard Drive and use the bad Hard Drive as secondary. Then you can copy the data from the second drive to first drive easily. Here have another process to recover data from a crashed Hard Disk. But it is so risky, and should not try to do this for an inexpert person. First pack the Hard Disk in a bag properly where moisture can't attack. Now freeze it upto get chill. After freezing quickly attach with a system in secondary, and copy the data within the Drive will come in room temperature.
So the most secure process to recover data from a Hard Disk is to use data recovery software. It is available in market.
on Mar 18, 2011 | Computers & Internet
Deleted partition recovery
You may recover deleted partition from Transcend USB drive with data recovery software, download from
http://www.asoftech.com/articles/transcend-data-recovery.html
hope this helps.
Nov 27, 2013 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have a Verbatim 500Gb (model #47566) hard drive. After defrag and clean up, when plugging in, I get a message that the disk in drive K is not formatted and would I like to format it now? I know that if I...
People often feel panic when I see this. If I format the drive, will I lose all my data? If not, how could I get access to my files?
My take is that you may have to format the drive (use quick format) and then use recovery software to recover your files.
Here's some information about file recovery, think you need to take a look, very useful
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 26, 2011 | Verbatim Portable, 500GB, USB, 5400rpm...
MY BUFFALO EXTERNAL HARD DISK HD PXTU2 IS SHOWING 297 GB UNALLOCATED. I THINK ITS PARTITION IS CORUPPTED
Hi guy,
You can try a partition recovery software to recover your corruptted partition.I have succeed to recover deleted partition with Tenorshare data recovery.It can recover deleted,formatted,corruptted partition after deeply scanning your hard drive to look for lost data.
Anyway,you can download a trial version and scan your hard drive for free to check out whether your partition can be recovered. http://www.any-data-recovery.com/index.htm
Jun 18, 2011 | Computers & Internet
I want to remove my patition
Perform the following steps which dddriver mentioned
But deleting partition means that your data will be lost from that volume.Its better take the backup of data otherwise your data get lost. To retrieved your data from deleted partition with the help of partition recovery tools. These tools are absolutely safe on the data in the drive and their only concern is to get back the lost data without altering the format.
Jun 13, 2011 | Computers & Internet
Data recovery from Portable Hard Disk
There are tools that will undelete & unformat you drive.
look here for free one.
http://www.softwarepatch.com/software/filerecovery.html
and here for a selection.http://www.freebyte.com/filediskutils/
finally this one is great but costs. http://www.easeus.com/
Feb 06, 2010 | Western Digital Passport 120GB External...
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
